Author Topic: GTI Exhaust Tip Removal  (Read 6142 times)
Offline willni
« on: 21 August 2021, 11:51 »
Does anyone know if you can remove the exhaust tips on the 7.5 GTI? I know the R's are removable but I think the GTI have a tig weld, is it just a matter of removing the weld?
Want to get them painted gloss black.
Offline DCmk3
Re: GTI Exhaust Tip Removal
« Reply #1 on: 21 August 2021, 16:47 »
"removing the weld"?
Why not just drop the exhaust off of the car, sand the tips and spray them if you really want to go that far.
They are welded on..
2014 Mk7 GTI - Littco L500
Offline willni
« Reply #2 on: 21 August 2021, 19:38 »
If it's a tig weld you just drill them out.
Because it's cheaper, quicker and gives a better end result by removing them and powder coating them, than painting when.
Offline Carbon VW
« Reply #3 on: 21 August 2021, 20:11 »
There are 2 spot welds that you would need to grind off.
Mk7 CSG GTi 6MF Stage 1, CSS backbox
Offline willni
« Reply #4 on: 22 August 2021, 08:10 »
Sweet Cheers Carbon!
Offline My other womans a vw.
« Reply #5 on: 22 August 2021, 08:39 »
There’s a guy on YouTube called ‘Last humans garage’,he has a 7.5 Gti and has done all sorts of mods to it.
He has done his exhaust tips and they look great.He originally bought some ‘Burger tips’,which slid on-or were supposed to-they are made for mk 7,not 7.5 which has a wider pipe.
He got round this by grinding off the tips,this enable the burger tips to slide straight on,I really liked these,it made the exhaust look bigger,without looking daft.
But for some reason he didn’t,he had another back box and sprayed the tips on that.
