Author Topic: Ross-Tech VCDS  (Read 3434 times)
Offline silver38
Ross-Tech VCDS
« on: 20 August 2021, 17:53 »
Anyone used VCDS and Hex+Can on a 2018 model year Golf or Polo?
Thanks
MKVII GTD Manual - Pure White, 5Door, Adaptive chassis control, Advance telephone connection, Climate comfort windscreen, Discover Nav pro, High beam assist, Keyless entry, Sport and Sound pack, Park assist system with steering assist, Rear view camera, Rear side airbags with rear seatbelt warning, Winter pack, 5 Year Warranty
Offline willni
Re: Ross-Tech VCDS
« Reply #1 on: 20 August 2021, 18:51 »
Yep used it for a few things.
Offline silver38
Re: Ross-Tech VCDS
« Reply #2 on: 20 August 2021, 19:25 »
Thanks for that.
What version VCDS?
Offline willni
Re: Ross-Tech VCDS
« Reply #3 on: 20 August 2021, 19:41 »
Thanks for that.
What version VCDS?
The latest version, is it 21.3? What do you need a hand with?
Offline silver38
Re: Ross-Tech VCDS
« Reply #4 on: 20 August 2021, 20:11 »
I wanted to look at the advanced measuring values for the auto trans on my Polo GTI+.
I'm using 21.3.0.0, this is what i get after an auto scan
Address 02: Auto Trans (J743)       Labels: 0D9-927-770.clb
   Part No SW: 0D9 300 043 G    HW: 02E 927 770 AS
   Component: DQ250-6F MQB  H54 5503
   Revision: 06454104    Serial number: TFK01907070125
   Coding: 0014
   Shop #: WSC 04742 780 00200
   ASAM Dataset: EV_TCMDQ250021 001001
   ROD: N/A
   VCID: 1E33F23D01B3AA7BD1-804A
Unsupported vehicle.Please upgrade to a current Ross-Tech interface.
No ASAM data for: "EV_TCMDQ250021" ()
No fault code found.
I asked Ross-Tech support with an older version of software, this is part of the reply.
No, you need a newer version for newer cars, not an older version.
2019 and newer model year vehicles are not supported by your HEX+CAN as explained here:
https://forums.ross-tech.com/index.php?threads/13715/
Offline willni
Re: Ross-Tech VCDS
« Reply #5 on: 20 August 2021, 20:35 »
Ah right I use the HEX-V2.
You've answered your own question though that the HEX+Can is no longer supported for newer vehicles, if you want to scan the polo you'd need one of the newer models eg HEX-V2.
I'd assume they want people to upgrade to generate further income, rather than actual limitation from the OBD harness.
Offline silver38
Re: Ross-Tech VCDS
« Reply #6 on: 20 August 2021, 21:01 »
I was working on the assumption that the Polo was probably using for the most part, electronics similar to the Golf MK7/7.5 and what worked on the Golf Mk7/7.5
Offline DCmk3
Re: Ross-Tech VCDS
« Reply #7 on: 20 August 2021, 23:58 »
HEX-V2 uses a different board/chips within the connector allowing communication with newer modules.
Different protocols as well are likely the case.
Hence the Hex-can failing as it was designed/manufactured before the newer cars were made..
Seems from 2016 VAG started using different styles of communication modules hence the older cables no longer working on newer vehicles past said date.
Hardly a "income generation plan" that older technology cannot communicate with newer modules in vehicles.
2014 Mk7 GTI - Littco L500
