Author Topic: Wheel center caps  (Read 5726 times)
Offline mossy69
  • 2014 Gtd carbon grey pro nav dyn audio keyless wp
Wheel center caps
« on: 03 July 2021, 14:52 »
Hi there in after some new golf Gtd wheel centre caps was wondering if anyone has bought any cheaper ones than the dealership
2021 Gti moonstone grey 19 Adelaide HUD winter pack
2014 GTD carbon grey pro nav dyn audio keyless
Offline SRGTD
Re: Wheel center caps
« Reply #1 on: 03 July 2021, 16:12 »
I think some VW dealers may have online websites or sell via eBay. Those that do have an online presence may sell them a bit cheaper than you’d pay if you bought them over the counter at the dealers. Some independent eBay sellers also sell the genuine article.
I’d personally avoid the cheap copies as the quality can be questionable and the chrome effect VW emblem can take on the appearance of white worm corrosion, necessitating premature replacement.
Gone but not forgotten;
2016 Polo GTI; Blue Silk
Offline Guzzle
« Reply #2 on: 03 July 2021, 22:46 »
Steer clear of the cheapo ebay copies. They're often made from hard and brittle plastic, and the shiny logo is exposed to the elements.
7.5 GTD
Offline willni
« Reply #3 on: 04 July 2021, 13:51 »
As above buy the genuine ones they last longer and look better, from memory they're £12-£14 a pop or £100 if you want the fancy spinny ones.
Offline martin998877
« Reply #4 on: 09 August 2021, 12:35 »
Do you have to remove the wheel from the car to push the old caps out? Or can they be prised out with the wheel still fitted? With a small screwdriver or something?
Obviously new ones are pushed in from the outside of the wheel, it's the removal of the old one's I'm asking about.
Thanks
Golf GTi Mark 7 owner
Offline Gnasher
  • Formerly GnasherVXR
« Reply #5 on: 09 August 2021, 13:19 »
If the old ones are going in the bin anyway, I'd just carefully drill a hole (about the same size as the ones on the nut covers) and use the metal hook tool to get them off.
Safer then maybe taking the paint off the wheel.
2014 Golf GTI (PP) in Pure White with
Vienna Leather, Keyless Entry, High Beam Assist, Park Assist, Rear View Camera. Milltek Exhaust, Eibach Sportlines, 19" BBS SR wheels - SOLD!!!!!
2018 Audi TTRS in Nardo Grey with
Black pack, 20" Alloys, Privacy glass and Sports Exhaust. No mods yet!
Offline SRGTD
« Reply #6 on: 09 August 2021, 13:50 »
Thanks
I certainly wouldn’t prise them out with anything like a screwdriver if your alloys are diamond cut and the diamond cut surface extends right up to the centre cap. Damage to the lacquered surface from a screwdriver or similar tool is likely to result in the onset of white worm corrosion.
If you’re not removing the wheels to push the caps out from the reverse side, the method that @Gnasher has suggested is the safest. Before drilling the hole, I’d also stick a piece of masking tape on the face of the centre cap so when you start drilling, the drill bit is less likely to slip.
Offline willni
« Reply #7 on: 09 August 2021, 14:00 »
Ah I guess I'm the only one that uses a screwdriver and hammers it through and then remove it with the nut cap removal tool in the boot.
If not just wait until next tyre rotation and do it properly.
Offline Gnasher
« Reply #8 on: 13 August 2021, 17:35 »
Hadn't thought of that one, but it'd work - the same tool as I'd have used but a different hole making philosophy!
« Reply #9 on: 14 August 2021, 10:24 »
I used a blunt kitchen knife, levering against the centre cap outwards, and they came out with virtually no force at all. No pressure or marking to the alloyse, no mvisible marking to the centre cap either.
Makes me surprised they don't all get pinched!
Anyway, definitely no need to take the wheel off to get them out.
