Author Topic: Map Updates  (Read 31744 times)
Offline mcmaddy
Re: Map Updates
« Reply #70 on: 23 July 2021, 10:27 »
I think the version and part numbers might be different for a pro Nav compared to Discover Nav even though they technically use the same maps.
Offline CS#303
Re: Map Updates
« Reply #71 on: 23 July 2021, 12:34 »
Ah OK, maybe it is done then.
This is what I have:-
Offline mcmaddy
Re: Map Updates
« Reply #72 on: 23 July 2021, 14:02 »
Go to your maps and then settings and then press version information. You should see the same screen as what others have posted up. 👍
Offline CS#303
Re: Map Updates
« Reply #73 on: 26 July 2021, 09:55 »
Well this is what I have, it still accepts the new data as a valid update, but nothing changes.
I'll assume it's the latest, and leave it as is. I don't really use it anyway  :wink:
Thanks all!
J.
Offline mcmaddy
Re: Map Updates
« Reply #74 on: 26 July 2021, 11:05 »
I think if your unit picks up the update and loads it in then it works. It doesn't reset the unit or do anything fancy. 👍
Offline Finglonga
Re: Map Updates
« Reply #75 on: 18 August 2021, 08:04 »
Ignore I was talking rubbish. :grin:
« Last Edit: 18 August 2021, 08:18 by Finglonga »
Offline mcmaddy
Re: Map Updates
« Reply #76 on: 06 December 2021, 12:29 »
New maps were released at the end of November if anyone's interested 👍
Offline Graemehaw
Re: Map Updates
« Reply #77 on: 09 December 2021, 19:36 »
Hi, can anyone help me with this? My 2014 golf gti has no sd card but maps still work. Is that right?
Also how do I know what my infotainment system is? Is there an easy way to tell?
Thanks in advance
« Last Edit: 09 December 2021, 19:38 by Graemehaw »
Offline madstaff
Re: Map Updates
« Reply #78 on: 09 December 2021, 19:40 »
Thanks in advance
https://app-connect.volkswagen.com/mapupdates/car/
Offline Graemehaw
Re: Map Updates
« Reply #79 on: 09 December 2021, 19:45 »
Thanks
So I have discover pro. Can anyone answer whether the sat should work without any sd card?
Also is there much difference between the discovery Pro on mine and discover pro on a 2017 on? They look totally different
Same updates for both?
« Last Edit: 09 December 2021, 19:48 by Graemehaw »
