Author Topic: Map Updates  (Read 31740 times)
Offline Nuggsy71
Map Updates
« on: 28 June 2021, 15:43 »
New version of maps now available if anyone still bothers !
Gone : Golf MKVI GTD 3DR Manual, Black Pearl -Also now Gone MKVII Golf Gtd 3DR DSG Pure White, Pro Sat Nav, Leather, ACC, Keyless Entry.
Gone : 5dr GTI DSG, PP, Leather, Keyless, Tech Pack, Tornado red
Current: Golf 7.5 Gti PP Indium Grey, Leather, Dynaudio, DCC, Climate Windscreen
Offline Finglonga
Re: Map Updates
« Reply #1 on: 28 June 2021, 16:18 »
Still the old ones I already have on the VW site?
Offline Rudedog
Re: Map Updates
« Reply #2 on: 28 June 2021, 16:26 »
Looks like the update date was for the 21st (June) so that's newer than my version from several months ago.
I'll do the update to my SD card later once I'm home.
Offline coolhandluke123
Re: Map Updates
« Reply #3 on: 28 June 2021, 18:37 »
Is there much to doing the update?
« Last Edit: 28 June 2021, 18:40 by coolhandluke123 »
Offline rwleigh
  • Richard.
Re: Map Updates
« Reply #4 on: 28 June 2021, 19:31 »
Downloading now, even though I mostly use Waze I like the car to be up to date...  :cool:
Golf GTI CS40 #010 | Manual | 5 door | Pure White | Car-Net | 90% tints | Winter Pack | REVO stage 1
Offline madstaff
Re: Map Updates
« Reply #5 on: 28 June 2021, 19:45 »
Downloading too, as my Nav Pro is still running 2017 maps.
Taking ages though.
Offline Miraclem
Re: Map Updates
« Reply #6 on: 28 June 2021, 19:54 »
no new maps for my discover media ...still 2020/11/23 release ... on pro have already  2021/06/21.. any idea, when they will launch new maps for discover care?
Offline Rudedog
Re: Map Updates
« Reply #7 on: 28 June 2021, 21:07 »
Looks like I'm on v13 and this new update goes to v14.7.
Yes it can be slow and make sure you have loads of free space on your HD to make backups while doing the copying.
Just seen Discover Care, isn't that just a way of automating the download if it detects and update?  You can still do the same thing manually.
Offline Rudedog
Re: Map Updates
« Reply #8 on: 28 June 2021, 21:56 »
OK there maybe a problem with upgrading to v14.7 from v13.
You need to check your SD card size, the new version is 16.34 GB and the standard VW card that came with my car is only 16GB, v13 just scraps in at 15.49GB.
As has been highlighted before unfortunately I could only get the upgrades to work using the VW card that came with my car rather than a third party card.
What do others think about asking dealers to see if they have any bigger cards that might give out FoC, effectively the maps are only going to get bigger so I really need a 32GB otherwise I'm going to be stuck on v13 unless I go to map option 2 which should be smaller as it has less countries listed.
Maybe they'll have a few spare now the MK8 has done away with the SD cards for satnav.
Offline CS#303
Re: Map Updates
« Reply #9 on: 29 June 2021, 09:45 »
Ditto!
 :wink:
