Author Topic: Coding Reverse Camera  (Read 5486 times)
Offline axe1986
« on: 28 June 2021, 12:25 »
Hi All,
Does anyone know where i can get the VW reverse camera retrofit coded to work? Is it VW only who can do it?
Thanks in advance
Offline BillSan
Re: Coding Reverse Camera
« Reply #1 on: 28 June 2021, 16:04 »
Hi Axe,
Are you saying that you've had a retrofit reverse camera fitted and it's not working properly?
I wanted a reverse camera on my Clubsport but I got a car from stock, as many others have, so no camera was fitted. When I asked VW about a retrofit they were totally uninterested in having anything to do with it and advised against it
Offline axe1986
« Reply #2 on: 29 June 2021, 08:40 »
Hi Axe,
Hi, Yes that's correct. Self retro fitted but needs coding afterwards
Offline clarky92
« Reply #3 on: 29 June 2021, 08:58 »
Hi All,
Thanks in advance
You could try vwretrofit in Redditch - he did the same to my 7.5 GTI and it worked perfectly
However saying that, I’m not sure anyone has managed to make changes to a MK8 yet
Offline massimo23
« Reply #4 on: 06 July 2021, 10:52 »
Advanced In-Car technologies have installed and coded the reverse camera on the Golf 8:
https://youtu.be/HfWFzjWA5BA
The Infotainment unit needs to be coded which is SFD protected...
