Author Topic: DRL's on an R-Line with IQ Headlights  (Read 6535 times)
Offline wizzywig27
« on: 22 June 2021, 15:05 »
Does anyone's DRL's turn off when any of the lights are on, such as dipped or main beam?
Offline fredgroves
Re: DRL's on an R-Line with IQ Headlights
« Reply #1 on: 22 June 2021, 20:42 »
When you say DRL, you mean the ones that are part of the headlight unit?
Offline wizzywig27
« Reply #2 on: 23 June 2021, 08:04 »
Yes, that's the ones
Offline bjbanny
« Reply #3 on: 23 June 2021, 21:10 »
Yes the DRL on main headlight goes dimmer when the headlights is switched on and the middle light bar comes on
ordered on 30/09/2020
GTI, Pure White, Business Premium Pack, Fog light, Tinted side & rear windows,   "Richmond" alloy wheels 18, Belmont winter wheels,  IQ.LIGHT  LED Metrix, pick up Autostadt Wolfsburg.
Offline buttons
« Reply #4 on: 24 June 2021, 08:50 »
isnt that the case with most cars.....
MK8 GTi: Adelaide 19", DCC, Winter Pack, Rear Camera and sh!t loads of software issues! ;-)
Offline wizzywig27
« Reply #5 on: 24 June 2021, 09:02 »
Thank you
Offline wizzywig27
« Reply #6 on: 24 June 2021, 09:03 »
Didn't on my A3
Offline SRGTD
« Reply #7 on: 24 June 2021, 10:37 »
Yes, it is.
The normal intensity of LED DRL’s is too bright for night time use, and there’s a risk they would dazzle oncoming road users during hours of darkness. When the headlights are illuminated, the bank or strip of LED’s used for the DRL’s will still be lit, but it should dim down. Presumably that’s why the government guidelines on their use refers to the DRL’s turning off when the headlights are on - effectively, the DRL function changes from high intensity DRL to lower intensity sidelight. The DRL’s also double up as parking lights - again at a reduced level of intensity when in use so they don’t dazzle oncoming road users.
From the Governent Guidance on DRL’s. Reference below to ‘position lamps’ means sidelights or parking lights;
’Dedicated daytime running lights
Daytime running lights (DRL) are purpose-made, low-wattage lights that can be fitted to a vehicle and used during the day to improve the visibility of a vehicle to other drivers as well as pedestrians, cyclists and other road users. They do not need to be operated manually as they automatically activate when the engine is started and turn off when the engine stops or when headlights are switched on at night.
DRL are necessarily bright to ensure they are visible in the daytime but not so bright that they will dazzle others. However they are too bright for night time use and are not intended to illuminate the road in the dark. If used at night they will cause dazzle and discomfort to others and so drivers should always switch to their position lamps or headlamps at night.’
https://www.gov.uk/government/publications/daytime-running-lights/daytime-running-lights
Gone but not forgotten;
2016 Polo GTI; Blue Silk
Offline wizzywig27
« Reply #8 on: 25 June 2021, 18:29 »
Yes, it is.
Stayed exactly the same on my A3
Offline SRGTD
« Reply #9 on: 25 June 2021, 18:56 »
Did you have LED matrix headlights on your A3? If so, then maybe LED matrix headlamps on Audis are ‘‘intelligent’ enough to auto dim or switch off the DRL LED’s when the car’s sensors detect oncoming vehicles approaching, but at all other times they’re at full intensity (e.g. during daylight or at night time when there’s no approaching traffic).
If they do work this way, then you’re unlikely to be aware the DRL’s are doing this from the driver’s seat.
« Last Edit: 25 June 2021, 19:14 by SRGTD »
