Author Topic: wishbone thread partially stripped!!!!  (Read 924 times)
Offline york1e
« on: 17 October 2005, 14:26 »
Hello there
I'm a new member - so if I've posted in the wrong place - I apologise in advance.
Front wishbone-rear bush: The bolt going into the chassis is partially stripped - I discovered this as I was told that the bushing needed replacing to stop the infernal knocking - has anybody had this problem before? is it just a case of finding someone to run a tap through it from above?
HELP!!
I'm not always in the forum - so if you have a top tip can you email me(see below)
cheers
Phil
Phillipyork@gmail.com
« Last Edit: 17 October 2005, 15:08 by york1e »
Re: wishbone thread partially stripped!!!!
« Reply #1 on: 17 October 2005, 15:28 »
If it is only stripped and not sheared off I think VW do a slightly larger bolt which will fix the prob :)
If the welds have given way & it's just spinning, then you'll have to cut a hole in the footwell!
If you lift the carpet there is a round blanking plate, remove this then cut downwards a little.  Then you'll need to weld a replacement nut in there, weld the hole back up & rust-proof the area.
Offline york1e
« Reply #2 on: 17 October 2005, 15:41 »
its not spinning - it nips up but I dont think its taking up all the thread - what there is of it anyway. I'll give VW a shout and badger them about the longer bolt. the last thing I want to do is cut a hole in me footwell!! - its only 2 weeks old!!
cheers for that fella - here's to the end of the infernal knocking!!
Phil
Offline Deefadog
  • Mk2 16V (November 89)
« Reply #3 on: 17 October 2005, 19:36 »
It's not for girls!
sorry mate could not resist - your user name that is, sorry i have nothing of value to add to this thread, please ignore me :)
Hope you get it sorted!
Offline york1e
« Reply #4 on: 18 October 2005, 09:19 »
No worries
but show me a woman that doesn't want a yorkie in 'er mouth!!! :evil:
(admittedly business has been slow. . . )
