Author Topic: MK7 Clubsport - Bonnet Pull Snapped  (Read 2424 times)
Offline spdpug98
« on: 21 June 2021, 10:37 »
I've done a quick search but not found anything, has anyone had their bonnet pull snap under the bonnet stopping you from being able to open it. Mine snapped yesterday as I was going to open it to clean underneath, I've heard horror stories of people cutting through the front grill to get to the fixings on the bonnet catch :shocked:
My car is still covered by the VW extended warranty and wondered if I'd have any chance with the them looking / sorting it out, I will be calling them but through I'd ask on here if anyone has had the same issue and if VW sorted it
Offline sjw
Re: MK7 Clubsport - Bonnet Pull Snapped
« Reply #1 on: 21 June 2021, 10:54 »
Sorry, which part is broken? The bit on the front edge that you squeeze, or the bit inside the driver's door?
If it's the former, can't you use a screwdriver or something to lever the catch? I would've thought it was quite a straight forward mechanism. I may be wrong though
Offline willni
« Reply #2 on: 21 June 2021, 11:02 »
If you've warranty, use it. No point trying to do it yourself to crack the grill or anything and then have to pay for it yourself!
It's a common fault the junction box on for the latch breaks open and disconnects itself. Once repaired put two cable ties on it to stop it from happening again.  :smiley:
Offline spdpug98
« Reply #3 on: 21 June 2021, 11:04 »
I think it's the piece above the headlight under the bonnet where the two cables join, the cable is still secured in the handle below the dash so assuming its the piece above the headlight
Offline spdpug98
« Reply #4 on: 21 June 2021, 11:11 »
Thanks, Its booked in with them to have a look............I did tell them it appears to be the common fault that MK7's have.....lets see what they come up with
