Author Topic: A more comfortable ride on GTI  (Read 8335 times)
Offline Bradders
« on: 04 June 2021, 20:36 »
Can anyone suggest a spring replacement to make my standard ride more comfortable on GTI 7.5 ?
« Last Edit: 05 June 2021, 20:14 by Bradders »
Offline Guzzle
Re: A more comfortable ride
« Reply #1 on: 04 June 2021, 21:37 »
What is your current setup?
7.5 GTD
Offline Bradders
Re: A more comfortable ride on GTI
« Reply #2 on: 05 June 2021, 20:14 »
sorry, should of added - Standard 7.5 GTI PP
Offline fredgroves
« Reply #3 on: 05 June 2021, 21:10 »
Have you considered swapping to lightweight 17's and some higher profile tyres?
In Germany the mk7 gti comes as standard on 17's. I'd not buy oem wheels though, definitely look for something nice and light.
That should be a fair bit more comfortable and not actually effect performance, quite the reverse actually. Also your tyres will be cheaper too!
Offline baka
« Reply #4 on: 05 June 2021, 22:32 »
Can confirm, I found the stock ride a bit much too and imported a set of those OEM 17's from Germany.  :whistle:
Seriously considered some Team Dynamics Pro Race wheels, as they are very light, but wanted to keep everything as stock looking as possible.
It certainly improves the ride over potholes, speedbumps and broken pavement a lot, quieter too.
Offline Bradders
« Reply #5 on: 06 June 2021, 00:58 »
I'd rather not have to buy a set of new wheels and tyres. I'd prefer to change the spring / dampers if possible
Offline willni
« Reply #6 on: 06 June 2021, 07:57 »
The only real option then is put standard Golf suspension in the car where the car will sit higher.
« Reply #7 on: 06 June 2021, 12:32 »
A set of second hand 17” wheels with 4 new balloon tyres would be a lot cheaper than a new set of decent gas pressurised dampers and Golf TDI springs plus associated fitting costs and alignment etc.
Seriously, if going to all that trouble to fit wobbly suspension to a sports hatch I think I’d rather just chop the car in for something French and be done with it.
Firstly the springs would have to be correctly load rated for the weight and output of the engine/gearbox combo and then declared as a modification to the vehicle. Then you’d have to make sure the dampers matched the springs and other ancillaries likewise, plus you’d have to fully set up the suspension for the changed ride height which will likely affect much of the geometry settings...
In the past I’ve found on previous generation Golfs that just adding uprated gas dampers from the likes of Bilstein or Koni (not their very hardcore sports dampers) but retaining the standard factory springs did improve ride and handling, with the higher quality dampers controlling the spring oscillations better. But on the MQB cars that balance is already pretty good even on 19” wheels.
I think you bought the wrong car for you.
Online Adam T7
« Reply #8 on: 06 June 2021, 13:06 »
Totally agree, like buying a set of gym weights and then try to make them lighter.
Offline fredgroves
« Reply #9 on: 06 June 2021, 14:18 »
Springs and dampers (and I think you'd need both) are a pretty serious upgrade and it's the kind of thing that puts you into really specialist insurance territory.
Wheel downgrade they might even accept as a zero cost change...particularly with oem.
What were you driving before that makes you think the gti is hard? I know it's all relative... Are you sure your car hasn't been modified already with some performance parts?
