Author Topic: Hard wiring dashcam  (Read 5202 times)
Offline valentino
Hard wiring dashcam
« on: 17 May 2021, 20:11 »
Have hard wired my dash cam into a golf GTI mk7.5, but has any one hard wired one into the MK8 GTI?
Thanks
Offline Ubique
Re: Hard wiring dashcam
« Reply #1 on: 17 May 2021, 21:04 »
Had mine fitted at halfords, £35 took an hour.
Offline Dave1rs
« Reply #2 on: 17 May 2021, 21:39 »
Yep front and rear,took 15 minutes for the front,bit longer for the rear due to routing the wires.
Offline P Doc
« Reply #3 on: 18 May 2021, 12:44 »
Any hints/tips etc for where to connect it?   have Garmin dash cams but only use switched power and earth.
cheers folks
John
2021 Golf GTI White, Pan Roof, Adelaides, DCC, Towbar
2021 Golf GTI Black, HUD, Harmon Kardon
2018 T-Roc 1.6 TDI-CR
2018 Up! Move up
previously, 2xup! Whites, 2x polos, Golf R, Golf R estate, Tiguan 4Motion, Amarok, UP GTi, Audi TT Quattro
VW addicts
Offline Dave1rs
« Reply #4 on: 18 May 2021, 15:20 »
If you can wait till Friday I will check what fuse I wired too.
Lots of room for the wires under the edge of the headliner(rear one),time consuming part was feeding the wire through the rubber wiring sleeve to the hatchback.
Offline P Doc
« Reply #5 on: 19 May 2021, 10:32 »
Thanks Dave, No Hurry, Only collecting them both tomorrow
2018 Up! Move up
VW addicts
Offline valentino
« Reply #6 on: 31 May 2021, 12:55 »
Fitted today, no probs. Took about one hour. Thanks for the advice Dave
Offline Smoggie
« Reply #7 on: 31 July 2021, 15:38 »
Fuse no 52 is the fuse to piggyback. Earth point just under ens panel of dash, small hole on frame just use nut and bolt.
