Author Topic: Battery check.  (Read 4691 times)
Offline Guzzle
Re: Battery check.
« Reply #10 on: 20 May 2021, 22:09 »
I've got the Halfords AGM battery in mine. So far so good. I believe it's actually made by Yuasa and it has a 5 year warranty 👍
If you're going to fit it yourself the Bosch AGM battery also has a 5 year warranty and is another good option.
7.5 GTD
Offline joe6
Re: Battery check.
« Reply #11 on: 26 May 2021, 09:09 »
May be worth trying an intelligent battery charger as most have a repair function that is supposed to desulphate the plates and restore some of the charge capability. At about 40 pounds seem quite reasonable.
Offline rwleigh
  • Richard.
Re: Battery check.
« Reply #12 on: 27 May 2021, 14:58 »
I use a CTEK MXS-5.0 which has a reconditioning mode that I use maybe once a year.
This shows what it does in the various modes.
Golf GTI CS40 #010 | Manual | 5 door | Pure White | Car-Net | 90% tints | Winter Pack | REVO stage 1
Offline Lordie
Re: Battery check.
« Reply #13 on: 28 May 2021, 21:43 »
So random question. When I hold the trip button below the speedo to check the battery level is says the StateOfCharge is 60% or 70%. What should the correct reading for a healthy battery be? (baring in mind I only really drive it on the weekends).
Thanks
Online Watts
Re: Battery check.
« Reply #14 on: 28 May 2021, 22:06 »
Thanks
I'll try and remember to check mine and let you know.
Previously:
Offline rwleigh
  • Richard.
Re: Battery check.
« Reply #15 on: 29 May 2021, 11:17 »
Thanks
It should be 100%, I would get a charger if I were you. You're obviously not doing enough mileage to keep the battery full and therefore it will fail early like so many others.
Here's my battery SOC today.
