Author Topic: Anyone know what this is? (Piece hanging from car)  (Read 4588 times)
Offline thronetm
I popped this part back into place but not sure what happened. Anyone know what it might be for? Just looks like a bit of plastic to me. I actually did notice it was loose a week back when cleaning the car but didnt think nothing of it.
Suspect a power wash might knock it loose again..
Offline DCmk3
Re: Anyone know what this is? (Piece hanging from car)
« Reply #1 on: 10 May 2021, 19:12 »
The tow hook cover..
2014 Mk7 GTI - Littco L500
Offline monkeyhanger
« Reply #2 on: 10 May 2021, 19:32 »
Yep, towing eye from the tool kit screws into the recess with the cover removed.
Offline fredgroves
« Reply #3 on: 10 May 2021, 19:56 »
That plastic string thing should clip on the car to keep it retained.
Offline thronetm
« Reply #4 on: 10 May 2021, 20:23 »
Interesting, thanks.
The plastic string, if you zoom in on the first picture, was just threaded through the bottom hole. However I was able to wiggle it out, before putting it, and clipping the platic piece, back in.
I assume that is not normal, when you mention it should be clipped to the car?
Offline fredgroves
« Reply #5 on: 10 May 2021, 20:56 »
To use the towing eye socket you pop the cover off and leave it dangling by the plastic string... That's why it's there.
Offline thronetm
« Reply #6 on: 10 May 2021, 21:21 »
Yes get that, the query was if the plastic string should be threaded through the bottom hole and no more? It seems a little bit flimsy is all but now that I've clipped it back in, maybe it'll be fine.
Offline fredgroves
« Reply #7 on: 10 May 2021, 22:07 »
That diamond shaped bit goes in the hole and it expands so it can't pull through.
Offline thronetm
« Reply #8 on: 10 May 2021, 23:13 »
Thanks Fred. I have it back in there so hopefully that's the end of it
