Author Topic: Reseting the MFA?  (Read 2729 times)
Offline Rodreguez
Reseting the MFA?
« on: 28 October 2003, 10:37 »
Been driving my golf for a month nearly and I still cant work out how to reset the MFA!
When I pulled up at a petrol station the other day it reset itself or did i do something to do this?
Also I noticed that it wont switch between Temp, engine temp, MPG etc when I press the MFA button only sometimes.
Is this cos it is on the way out? and is it easy to replace??
Offline sKrEwBaLL
Re:Reseting the MFA?
« Reply #1 on: 28 October 2003, 10:38 »
Hold the button in to reset the figures
golfvr6
« Reply #2 on: 28 October 2003, 10:40 »
To reset it hold either of the settings to zero. Sounds like the switch is on the way out. You may be able to take it apart and clean it up, but if you do be prepared to buy a new one incase it breaks!
Offline Gambit
« Reply #3 on: 28 October 2003, 10:41 »
first of id check to make sure the connector below the steering coloumn isnt back to front
if it is, then pressing the MFA button will reset it, and then shifting the 1 to its reset place will cycle thru the functions! took me a month or so to work out what was wrong!
just take of the bottom of the steering coloum surround (2 screws) and it will reveal the plug between the stalk and the MFA
Offline Gambit
« Reply #4 on: 28 October 2003, 10:42 »
i have a spare set of working stalks ;)
they are late spec and have the hazard light swith on top of the steering coloum
« Last Edit: 28 October 2003, 10:42 by Gambit »
Offline Rodreguez
« Reply #5 on: 28 October 2003, 10:46 »
Woah! that response was rapid!
Thanks a lot.  Training to be an auto elecy should be able to do it.
Gambit where abouts are you mate?
Offline sKrEwBaLL
« Reply #6 on: 28 October 2003, 10:49 »
We dont mess about here mate.  Must be something to do with the fact we're all slackers at work  :o
Offline Gambit
« Reply #7 on: 28 October 2003, 10:55 »
Isle of Man mate :lol: but they can be easily posted i still have the original pacakagin they came in!!
