Author Topic: 7.5 GTI DSG oil and filter change  (Read 7957 times)
Offline Adam T7
« on: 21 April 2021, 07:31 »
When do folk recommend changing the filter and oil in terms of age and/or mileage.
I’ve only done 10k and the car is nearly 30 months old from new.
Offline fredgroves
Re: 7.5 GTI DSG oil and filter change
« Reply #1 on: 21 April 2021, 09:00 »
When the service interval tells you?
The car will tell you when an oil change is needed, should be on an annual cycle if you are doing low mileage.
Offline Adam T7
« Reply #2 on: 21 April 2021, 09:16 »
Car will tell me based on VW’s algorithm. Having had a Discovery that had a BorgWarner 7 speed Auto box (different tech I know) that was ‘Sealed for Life’ and never appeared in the Service interval, yet BorgWarner recommended 100k mile oil and filter change I was interested in folks real life experiences?
Lots of Discovery’s were having issues at about 125k with auto boxes due to lack of maintenance.
Offline Yusee
« Reply #3 on: 21 April 2021, 09:27 »
That's interesting. I think when problems start appearing at that kind of mileage, it's a toss up as to whether something is a serviceable item or not
Offline Aparat
« Reply #4 on: 21 April 2021, 09:37 »
I might be wrong so please correct me if so but Its 40k for 6 speed and 80k for 7speed box  :huh:
Offline fredgroves
« Reply #5 on: 21 April 2021, 09:41 »
According to the internet:
Quote
After the synthetic/mineral debacle some VAG dealers took the view that the dry clutch 7-speed DSG needed an oil change every 40,000 miles, but the official Volkswagen line is that they don't. The 6-speed wet clutch DSG is a maintenance box and does need fresh oil and filter every 40,000 miles
So DSG6, definitely change the oil, DSG7.... probably a good idea to change the oil.
Offline fredgroves
« Reply #6 on: 21 April 2021, 09:42 »
In the world of Land Rovers, 125k is "delivery mileage"  :laugh:
Offline Rudedog
« Reply #7 on: 21 April 2021, 14:55 »
I've copied this from the TPS website regarding servicing of all DSG boxes.
Service intervals:
The table below gives an overview of these gearboxes and their service intervals:
Gearbox type   Gears   Service interval   Fluid*
DQ200   0CW   7-speed   No service interval   G 055512A2
DQ250   0D9   6-speed   40,000 miles - Fluid and filter   G 052182A2
DQ381   0GC   7-speed   80,000 miles - Fluid only   G 055529A2
DQ400**   0DD   6-speed   40,000 miles - Fluid only   G 052182A2
DQ500   0DL   7-speed   40,000 miles - Fluid only   G 052182A2
DQ500   0BH   7-speed   40,000 miles - Fluid only   G 052182A2
DL382   -   7-speed   40,000 miles - Fluid only   G 055529A2
DL501   -   7-speed   40,000 miles - Fluid and filter   G 052529A2
All of my DSG boxed cars have had a 40K mile interval (not years).
AFAIK all of the wet-clutch DSG boxes have a 40k interval (both 6 & 7 speed).
Offline madstaff
« Reply #8 on: 21 April 2021, 17:31 »
Does that TSB list the recommended service intervals for the manual box VAQ diff??
Offline willni
« Reply #9 on: 22 April 2021, 06:50 »
In the world of Land Rover, electronics are the service items :wink: :grin:
