Author Topic: Flashing red lights on both key fobs  (Read 20111 times)
Offline Don76
Re: Flashing red lights on both key fobs
« Reply #20 on: 07 May 2021, 09:08 »
Yes, I have keyless off.
I've worked out why it flashes even with keyless off.
It's to do with the convenience lighting. If you have it set to activate on approach the key light flashes. If you deactivate it, the light does not flash
I have this set to off and the fob continues to flash when within 10m of the car.
Offline Ubique
« Reply #21 on: 07 May 2021, 09:18 »
I just turned off that setting, blinking lights have stopped! 👍
Offline joet
« Reply #22 on: 07 May 2021, 09:39 »
Excellent! Another tip for the Volkswizard video!
Offline fredgroves
« Reply #23 on: 07 May 2021, 09:40 »
I definitely don't have that setting... Its a bw48 thing for sure.
Offline massimo23
« Reply #24 on: 07 May 2021, 13:39 »
I also dont have that setting. Can someone post a photo of this setting?
Offline joet
« Reply #25 on: 07 May 2021, 14:10 »
There you go
Offline massimo23
« Reply #26 on: 07 May 2021, 14:12 »
Thanks joet. I don't have this option. It must be only for the newer units 816D/820D...
