Author Topic: Flashing red lights on both key fobs  (Read 20122 times)
Offline fredgroves
Re: Flashing red lights on both key fobs
« Reply #10 on: 06 May 2021, 16:44 »
Well, it will talk with UWB but if you look at my thread on keyless, it should be quite close before it does it.
I've never seen mine do it...
Offline Ubique
« Reply #11 on: 06 May 2021, 16:52 »
I did point out that it appears to be BS to the service guy but he insisted that the master tech had looked it up so it must be true. I asked if I get free replacement batteries when the fobs die? Of course sir was the answer. 🤷‍♂️
Offline scMK8Clubsport
« Reply #12 on: 06 May 2021, 17:01 »
To confirm, my key fob has a small illuminating red light that flashes as I approach the vehicle.
It's clearly the key communicating with the car, irrespective of keyless entry being enabled or not.
Offline Ubique
« Reply #13 on: 06 May 2021, 18:18 »
Yes, I have keyless off.
Offline joet
« Reply #14 on: 06 May 2021, 19:35 »
I've worked out why it flashes even with keyless off.
It's to do with the convenience lighting. If you have it set to activate on approach the key light flashes. If you deactivate it, the light does not flash
Offline fredgroves
« Reply #15 on: 06 May 2021, 20:19 »
Ahhh convenience lighting... The thingy which someone else was asking why their car lit up when they walk near it...
Where is the settings for that?
Offline joet
« Reply #16 on: 06 May 2021, 20:32 »
Vehicle settings, exterior, comfort light.
Offline fredgroves
« Reply #17 on: 06 May 2021, 20:42 »
I guess you only want it on if you are using keyless and without unlock on approach... Because pressing the remote lights it up as does approach unlock...
Offline fredgroves
« Reply #18 on: 06 May 2021, 21:32 »
What is the setting in that menu? I don't have anything in there that does that... Suspect that's one of the bw48 things....
Offline joet
« Reply #19 on: 07 May 2021, 08:44 »
Strange.
On mine it's at the bottom of the menu. You have to scroll the screen to get to it. Below the leaving delay time
