Poll
What version of software is your car running?
1664
7 (8.4%)
1666
24 (28.9%)
1668
11 (13.3%)
1788
11 (13.3%)
Something else
30 (36.1%)
Total Members Voted: 79
Author Topic: Mk8 software version poll  (Read 305997 times)
Re: Mk8 software version poll
« Reply #650 on: 13 January 2023, 19:14 »
Do you need to be logged in as primary user to get the OTA update?
Offline Ceefeesh
« Reply #651 on: 13 January 2023, 19:41 »
I am logged in as primary user but I don’t know if it’s necessary. The OTA update notification appeared early this afternoon, it hadn’t been there earlier. I checked the version after the update and it has gone to 1899. I’ll look at the map availability on the dash tomorrow.
Offline fredgroves
« Reply #652 on: 14 January 2023, 17:46 »
Is 1899 the one that allows maps on the dash ? Or is that pro only ?
You've been able to get that with OBD11 since ages ago.... but 1896 seems to have enabled it by default. Use OBD11 to enable maps on both displays at once.
Offline fredgroves
« Reply #653 on: 15 January 2023, 16:51 »
I’m on 1896 so how do I get the map on both displays please ?
Do you have Obd11?
Offline fredgroves
« Reply #654 on: 15 January 2023, 20:08 »
Yes it needs Obd11
Offline BillSan
« Reply #655 on: 16 January 2023, 08:17 »
My CS has been on 1896 and is now on 1899, but I have never had the option to put maps on the dash display, even if I had something else in the centre display.
Offline Dave1rs
« Reply #656 on: 16 January 2023, 09:25 »
You have to tick the option on the sat nav screen, and then scroll through the dash displays to find the one with maps.
Offline Ubique
« Reply #657 on: 18 January 2023, 15:22 »
Offline Carlosfandango
« Reply #658 on: 21 January 2023, 11:08 »
I don't think the Front Assist works properly, if your windscreen has a covering of ice/frost or is misted up.
Mine was covered with frost first thing this morning, so I cleared it as best I could and drove it with the "Front Assist" warning for the first 1/2 mile or so. It worked fine after that, although I suppose I probably shouldn't have been driving the car at all, until my screen was completely clear.  :wink:
My old M135i xDrive had a heated section of screen where the camera was located, I’m guessing the MK8 doesn’t have the same!?
[/quote]
In answer to my own question!
It appears that the MK8 DOES indeed have a heated section of screen where the forward facing camera is located, I did the same as I did in the BMW and started the car without the climate on, then waited, if I had waited longer it seems the area that was defrosting was larger than pictured, as I could see the shape emerging from the frost, in addition, for anyone who is doubtful that LED headlights can melt frost or snow from the lens, I also took a picture of just that happening as I waited👌.
« Last Edit: 21 January 2023, 13:16 by Carlosfandango »
Current -
Gone -
2022 Mk8 GTI DSG, Kings Red.
2003 Mk4 R32, Reflex Silver.
1991 AX GT.
1984 Mk1 XR2.
Plus many more.
Offline BillSan
« Reply #659 on: 21 January 2023, 13:54 »
I went to the navigation screen today and couldn't see anything in settings to tick to display on the dashboard.  Could you take a screenshot or give me more detail please?
Thanks
