Author Topic: **URGENT** De-Badged Grille  (Read 1305 times)
Offline golf gti 16valve
« on: 16 October 2005, 15:39 »
hi ppl im just about to order a de badged grille from gsf, for my 88 mk2 gti golf, do you know if they are any good?? and do you know if i have to use the lower metal part of the grille with it?? the part that is painted and runs underneath the Headlights??? i would be very grateful for any help you could give me many thanks  :grin:
Offline Agreeable Slick
  • Unit
Re: **URGENT** De-Badged Grille
« Reply #1 on: 16 October 2005, 15:47 »
I've got one to sell, not got the painted bottom part though, there is a peice of plastic there beggin to be painted though.
« Reply #2 on: 16 October 2005, 16:10 »
msg sent! also do you think the metal part will go over the part thats beggin to be painted??
  • Unit
« Reply #3 on: 16 October 2005, 16:20 »
message sent.
« Last Edit: 19 October 2005, 15:15 by Large Portion with that luv' ?? »
Offline Neaty
« Reply #4 on: 19 October 2005, 12:43 »
I had to modify mine to fit, there are clips at the top in the slam panel and other clips underneath at the bottom near the bumper nut the dnt line up so i had to cut the ones at the bottom off so that i could get it to go on properly, looks good though!
  • Unit
« Reply #5 on: 19 October 2005, 15:15 »
mines a tried and tested fit, with no modification.  :smiley:
