Author Topic: Wiper arm removal to access Soundaktor  (Read 7966 times)
Offline king monkey
« on: 25 October 2020, 09:58 »
Hi everyone,
Advice needed. I’m trying to access the soundaktor to insulate but can’t reach it. If I take the wipers off I’ll get better access. I’ve undone the 13mm nut but the wiper arm won’t budge!
All ideas welcome!!
Thanks in advance.
Offline clubsport
Re: Wiper arm removal to access Soundaktor
« Reply #1 on: 25 October 2020, 11:21 »
The wiper arm sits on a tapered spline. You should be able to pull and wriggle it upwards, if really stuck (corroded) it may require a puller?
Offline st33ly
« Reply #2 on: 25 October 2020, 11:41 »
Amazon prime wiper arm puller bud. Use a cloth between the puller and the arm that way you won’t damage the arm. They are £8 I think.
Offline Al1040
« Reply #3 on: 25 October 2020, 16:08 »
+1 They are generally a little corroded (dissimilar metals and all that) gently does with with lots of wiggling :grin:
67 Plate Mk 7.5 GTD DSG
Offline Phil245
« Reply #4 on: 25 October 2020, 16:10 »
It is just about possible to both disconnect and remove the stupid soundaktor thing without taking the wipers off, although that may very well make it easier.....
I managed to wedge something between the scuttle and the bulkhead and get my hand in whilst an assistant shone a torch in.
I thought about donating the soundaktor to the local kindergarten in case there were any two year olds wanting it for their toy car, but instead I put it in the dustbin for landfill. In 200 years someone will dig it up and wonder what the stupid piece of sh*t is for.......
2019 Golf GTI 245 Performance, 2020 Skoda Karoq Sportline 2.0 TDI
Sadly sold, Octavia VRS245 Estate, Audi A3 1.5TFSI S Line Black Edition, Polo GTi 1.8, Audi TT Roadster, Golf Mk7 GTD etc.
Daughter has 2019 Polo 2.0GTi DSG. We love VAG !
Offline baka
« Reply #5 on: 25 October 2020, 16:36 »
You could code it out if you want to shut it up? I just turned it to 0% with OBDEleven.
Offline king monkey
« Reply #6 on: 25 October 2020, 17:50 »
Thanks for the replies. Wiper arms won’t budge still. Apparently Vw use one of those tools to get them off.
I’ve had a really frustrating day. Can’t fix the rattle, can’t get the new footrest to fit and the Amazon delivery driver thought it was a good idea to put my parcel on my car bonnet. Oh well, tomorrow’s another day!
Offline Vwjap
« Reply #7 on: 25 October 2020, 22:05 »
I had this problem on a focus a few days ago, found out it’s the spring pushing the wiper into the windscreen help it tight, worked out if you push the wiper arm towards the screen a few times it broke the seal and released the arm, dunno if it’s the same for the golf
Offline king monkey
« Reply #8 on: 26 October 2020, 06:04 »
Thanks. I’ll give it a go!
Offline Finglonga
« Reply #9 on: 26 October 2020, 09:50 »
I have had my screen replaced twice and both times they needed a puller to get the wiper arms off. As saud just code it out or unplug the dreadful thing, it is easy to unplug without removing wipers.
