Author Topic: Finally own a Golf and some issues!  (Read 2108 times)
Offline andybtsn
« on: 18 October 2020, 16:08 »
Hi all,
I used to be in on the VAG scene but mainly owning the Polo variety, a decade later and more I now own a 2015 Golf GTD after selling my BMW M135i. Hello to you all!
I've got a few issues. Firstly the ACC/Front assist does not work, it appears the actual sensor is broken although I'm having a garage run some diagnostics to confirm that, it's going to be a hefty repair bill!
Secondly, the front passenger parking sensor has been pushed into the bumper. I have read this is a bumper removal job to sort? Is this definitely right? There is no way the grills can't be removed and getting your hand to the sensor hole? Any ideas how much a garage would charge for this work?
Also there is some rust between the front and passenger door, should I do anything about this to prevent it 'spreading'? The car is really a clean example, rust a is a big disappointment on a 5 year old car :(
Attached a couple of pics.
Offline barrym381
Re: Finally own a Golf and some issues!
« Reply #1 on: 18 October 2020, 16:27 »
Welcome  :smiley to sort your sensor in front bumper either jack car up and take under tray off or take passenger wheel off and take wheel arch lining off to give you access to it  :smiley:
Offline andybtsn
« Reply #2 on: 18 October 2020, 19:49 »
Thanks, I think I can manage that..I was reading things of the whole bumper needing to be removed
Offline Adam T7
« Reply #3 on: 18 October 2020, 21:32 »
That rust is a scuff that’s been left, bit of fine wet and dry, kurust and a touch up, just a few quid and half an hours work.
Offline andybtsn
« Reply #4 on: 18 October 2020, 22:04 »
Thanks, any guides you recommend? I imagine it will be quite difficult not affecting the paint around it?
