Author Topic: Rattling/knocking noise when turning at low speed  (Read 2009 times)
Offline olivert
« on: 18 October 2020, 10:09 »
Recently bought a new to me 2016 Mk7 Performance Pack with a very low mileage (4000 miles). I took it out for its first drive and noticed a rattling/knocking noise from the front when turning at a 20 degree angle at less than 10mph. Lucky the repair is covered under warranty so I won’t be out of pocket but I was wondering if anyone else has had this problem before?
Offline chazzypuk
Re: Rattling/knocking noise when turning at low speed
« Reply #1 on: 19 October 2020, 11:43 »
Yeah I am having this issue too! I have a mk7 GTD 2014 and it has been making this noise for the last 6 months or so. It's going in for it's service in two weeks so I've asked them to look at it. Having done a google search it would appears it's something to do with the front suspension and requires lubricating. I came on the forum today to search for this issue specifically so a coincidence you posted recently about this issue too!
Golf GTD Mk7 3dr Manual, Pure White, Adaptive Chassis Control, Panoramic roof, Discover Pro Nav, Keyless entry, Dynaudio, Park assist, High beam assist, Leather pack, Service Pack.
Offline SRGTD
« Reply #2 on: 19 October 2020, 12:06 »
Could be a worn or damaged CV joint.
If the rubber CV boot has split allowing dirt to enter and the grease packed inside the boot around the joint to escape, then the joint can wear. If this happens, a tell tale sign is a loud clicking noise when turning, which would be more noticeable at slow speeds.
Gone but not forgotten;
2016 Polo GTI; Blue Silk
Offline olivert
« Reply #3 on: 23 October 2020, 23:05 »
