Author Topic: HELP ..... ACC Not Available  (Read 10995 times)
Offline rajb
Re: HELP ..... ACC Not Available
« Reply #10 on: 17 October 2020, 07:42 »
I cleared the fault and it’s never returned.
This like most errors is worth just trying first. Always a good chance it’s just thrown it at a particular test point and may be ok.
If it does return then you know it’s a definite issue.
Offline Philip
« Reply #11 on: 17 October 2020, 08:22 »
Disconnect the battery for 10-15 minutes, reconnect and the dash will light up with warning lights for a short time.  Ignore these and go for a five mile plus drive.  Then park up and turn off for another 10-15, on restart the ACC and collision protection should be the only errors you see, go for another five mile drive and it should clear.
TCR 3 door
Offline whogives
« Reply #12 on: 18 October 2020, 11:17 »
I had this same message around a year ago on my mk7 even though I hadn’t removed anything.
I read the controller with VCDS,the fault read,power supply intermittent or words to that effect.
Thanks for the quick replies :)   I've also seen on the net that VCDS is worth trying. I'm just trying to find a garage (Independent) who has it.
If I'm correct in thinking on the MK7 the radar was in the bottom grille, so wasn't effected when removing the bumper.
Offline whogives
« Reply #13 on: 18 October 2020, 11:19 »
Well I'll try anything,  thanks for the input :)
Offline Garhan
« Reply #14 on: 18 October 2020, 12:19 »
If your anywhere near Airdrie I’ll do it foc.
Offline whogives
« Reply #15 on: 18 October 2020, 12:33 »
Unfortunately not ... I'm a Birmingham boy (For my sin's)  But just like to point out I'm not in the lock Down area   :sick: :sick: ...LOL
But Thanks   :smiley:
Offline Talk-torque
« Reply #16 on: 18 October 2020, 13:38 »
Not sure whether Carista or OBD2 could clear this fault, but may be worth a lower cost try, if you can’t get help with VCDS. If either of those fails to clear the fault, you could still do quite a few useful mods!
Roger.
Offline whogives
« Reply #17 on: 18 October 2020, 16:07 »
Yer I've got OBD11, but not able to clear fault. I've also got my first MOT due next month, so not sure if it will fail, due to the faults on the dash ??
Offline rajb
« Reply #18 on: 19 October 2020, 07:04 »
Unfortunately dash warning lights are an MOT failure now.
Offline WD-40
« Reply #19 on: 19 October 2020, 13:40 »
What a load of tosh. When I hit the pheasant in my previous car it totally demolished the hanging bracket the radar sensor sat on. Got it all repaired which meant a new front cross member and then dealer just re attached the sensor. It never needed recalibrated and even when the sensor was slightly lose in its holder all the dealer did was put a bit of felt behind and then clipped it back in. Worked perfectly and at no point was recalibrated.
I similarly hit some wildlife (muntjac deer) and VW replaced the lower grill and ACC bracket and I also had to pay £300 for the sensor to be recalibrated.
Current:
2018 BMW M2
2002 Porsche 911 (996) Carrera 4
Ex:
2017 GTI Clubsport Edition 40 #645, MG Midget, Audi S4 Avant, Mercedes-AMG C63, Porsche Cayman S Sport, BMW Z4MR, Honda S2000, Alfa Romeo GTV, Peugeot 106 Rallye, Austin Mini E amongst others
