Author Topic: Replacing fuel flap actuator?  (Read 2026 times)
Offline Rob_benton
« on: 13 October 2020, 12:51 »
Hi. I need to replace my actuator. Has anyone ever done this? The videos I’ve seen show I need to remove the boot interior trim to access the wiring plug. Once I remove the bits from the fuel filler hole, Can I access the wiring plug from the fuel filler externally by reaching in ? Thanks
2014 gti pp dsg
Offline Watts
Re: Replacing fuel flap actuator?
« Reply #1 on: 13 October 2020, 17:01 »
I have done it, it is pretty straightforward but no, you can't access the electric plug from outside.
Previously:
Offline Rob_benton
« Reply #2 on: 13 October 2020, 17:39 »
Bugger.
Any tips on removing the interior trim. I’ve watched videos and looked at Workshop manual but not very clear.
Thanks
2014 gti pp dsg
Offline Watts
« Reply #3 on: 13 October 2020, 17:50 »
It wasn't that long ago that I did it but I can't remember too much about it now :embarrassed:. But it was easy, the plastic panel at the top I think had one screw and some clips but I don't think it needed removing, just loosening a bit so that the soft material lining could be pulled down and out of the way. I do seem to recall the interior light fitting coming out making things easier but tbh, online videos should have enough information. 15-20 minutes should be enough. If anything else comes to me I'll post it.
Previously:
Offline Rob_benton
« Reply #4 on: 13 October 2020, 20:22 »
Thanks
2014 gti pp dsg
