Author Topic: flashing coil light  (Read 2635 times)
Offline mossy69
  • 2014 Gtd carbon grey pro nav dyn audio keyless wp
flashing coil light
« on: 05 October 2020, 15:01 »
hi there I was driving home this morning and the diesel coil light was flashing the car also went into limp mode any ideas got the car booked in on Thursday cheers
2021 Gti moonstone grey 19 Adelaide HUD winter pack
2014 GTD carbon grey pro nav dyn audio keyless
Offline Guzzle
Re: flashing coil light
« Reply #1 on: 05 October 2020, 15:32 »
Could be any of a number of things. When it happened to my Octavia it was a faulty pressure boost sensor.
A simple fix, they're about £30 but it needs to be diagnosed first.
7.5 GTD
Offline mossy69
« Reply #2 on: 05 October 2020, 18:37 »
fingers crossed that's all it is ,I've heard it could be the heater plugs
Offline mossy69
« Reply #3 on: 07 October 2020, 10:51 »
just had vds diagnostics its the fuel pump and control module apparently its burned out and its quite common , and there's been no recall either from vw , I wonder why lol
Offline Al1040
« Reply #4 on: 07 October 2020, 12:17 »
That's a real shame mossy69, hope it doesn't cost too much to fix... I have not heard about that being a general problem do you have any more details?
67 Plate Mk 7.5 GTD DSG
Offline SRGTD
« Reply #5 on: 07 October 2020, 12:22 »
Unfortunately, being a quite common fault doesn’t make it a recall action. Leaking water pumps and thermostat housings are also quite common issues on the mk7 Golf but VW won’t cover the cost of replacing them unless the car is under warranty. A fault is only likely to be the subject of a recall unless it’s considered to represent a safety-related risk.
Hope you get it fixed soon and it’s not too costly.
Gone but not forgotten;
2016 Polo GTI; Blue Silk
Offline mossy69
« Reply #6 on: 23 October 2020, 16:07 »
all sorted now my local independent vw Audi genuine parts they only use   £465 ouchhhh
