Author Topic: Poi's disappearing on Discover Nav  (Read 3080 times)
Offline mcmaddy
« on: 03 September 2020, 21:27 »
Has anyone had any issues with Poi's disappearing from the screen. Not just my own speedcam ones but the preloaded ones built in disappear on start up. To get them back I have to press nav button twice. They've been perfectly fine for the last month but all of a sudden they've started to vanish. I've already reset the head unit which makes no difference. Anyone else had this issue?
Offline Watts
Re: Poi's disappearing on Discover Nav
« Reply #1 on: 03 September 2020, 21:33 »
I've not had any since I got the car, just assumed that was how it was supposed to be.
Previously:
Offline mcmaddy
« Reply #2 on: 03 September 2020, 22:08 »
have you got any selected Watts? By default none are selected so you'd have to pick the ones you wanted to show.
Offline Watts
« Reply #3 on: 04 September 2020, 07:44 »
Okay, thanks, probably not.
Previously:
Offline mcmaddy
« Reply #4 on: 04 September 2020, 08:13 »
So an update this morning. Started the car this morning and all POIs gone. Deleted all my own POIs from the memory and selected the pre installed petrol stations, VW's own poi. Drove to work and not one petrol station showing  :grin:
Reset the unit and even though my own POIs had been deleted it was showing Shell petrol stations! Also noticed that the first poi in the list is Autostadt so looks like incorrect software or firmware is on the unit as that's German.
Offline Sootchucker
« Reply #5 on: 04 September 2020, 08:30 »
Weird bud. Never had an issue like that on mine. Did you spring for the Discover Pro version or the standard 8" Discover Navigation ?
Offline mcmaddy
« Reply #6 on: 04 September 2020, 12:47 »
Went for the standard but wish I'd gone pro now  :grin:
To get them to return I have to press the view buttton, until POIs and then retick it.
Offline mcmaddy
« Reply #7 on: 04 September 2020, 12:48 »
Can others with standard Discover Nav check to see if Autostadt is available as a poi in the drop-down.
Offline Al1040
« Reply #8 on: 04 September 2020, 13:29 »
Hi mcmaddy, yes I can confirm that it is one of the options within the POI list.
67 Plate Mk 7.5 GTD DSG
Offline Sootchucker
« Reply #9 on: 04 September 2020, 16:17 »
Chris, yes Autostadt appears as one of the POI categories on mine too.
