Author Topic: Turning the car over  (Read 3756 times)
Offline Craig
« on: 22 August 2020, 16:29 »
Hey guys.
Looking for some advice. My car can sometimes sit for months and months not turning a wheel. I was wanting to turn the engine over a few times using the starter motor only to let the oil move around before starting properly. For anyone have any suggestions how I go about it safely?
Much appreciated. Thanks.
Offline barrym381
Re: Turning the car over
« Reply #1 on: 22 August 2020, 19:32 »
Hey guys.
If it’s a petrol car just unplug the coil packs
« Reply #2 on: 22 August 2020, 22:22 »
The oil is very thin so I’d just fire it up normally once in a while and run the engine up to temperature.
That’ll help the aircon system seals too.
Offline monkeyhanger
« Reply #3 on: 22 August 2020, 22:56 »
Do you not have 5mins every 3 weeks  to run it around the block?
If its a manual I'd be worried about the clutch plates seizing, and regardless of transmission I'd be concerned that the brakes don't bind. You need to move the car once in a while, not just worry about the engine turning over.
Offline Finglonga
« Reply #4 on: 23 August 2020, 09:07 »
Yep, but needs to be up to temperature for a while to get rid of condensation as that could cause more damage than good. It could also do with moving to get oil around the gearbox.
Offline DCmk3
« Reply #5 on: 23 August 2020, 10:25 »
Hey guys.
To be fair that wouldn't be advisable as you will then just dump fuel into the cylinders and create a borewash scenario as well as fill the oil with fuel as it then drains past the rings.
2014 Mk7 GTI - Littco L500
Offline dubber36
« Reply #6 on: 23 August 2020, 19:35 »
My Mk2 is off the road for six months over winter. I start it, get it up to temperature and move it up and down the drive a couple of times a month. The other thing to consider is your tyres becoming mis-shapen. Adding an extra 10PSI will help them keep their shape, but leave a note on the dash to remind you before you next take it up the road.
Offline Craig
« Reply #7 on: 26 August 2020, 03:17 »
Thanks for all the comments guys. I was hoping if I could pull the fuse for say the fuel pump it would just let the car turn over a good few times. Then plug it in and let the car start.
