Author Topic: Vw golf mk6 gtd 59 drl issue  (Read 23385 times)
Offline S4tyh
« on: 18 August 2020, 17:58 »
« Last Edit: 10 March 2022, 18:09 by S4tyh »
Offline Snoopy
  • Moderator
  • Geoff.
DRL LED Xenons BCM what needed
« Reply #1 on: 18 August 2020, 18:33 »
Just a note but if its a 59 it wouldn't  have had leds rear from the factory. Only optional front xenons could be ordered, LED rears not until build week 22 of 2010.
On a 2009 your BCM will probably not support the front DRL LEDs and what will happen is you won't get fault codes but the LEDs simply won't light up. This is what happens with BCMs with part number 1k0 937 087D software version 0537. You need at least software version 0575.
On a 2009 with factory xenons what is required is the newer LED light lenses 5k2 941 754 d + 5k2 941 753 d and BCM 1k0 937 087 E (software ver 0575). The rest of the bits just transfer from the older lights. Then just code them in. When i say just what i should have said is theres quite a few bits of coding to change.
« Last Edit: 18 August 2020, 20:29 by Snoopy »
Current Garage:
35+ years of GTI ownership.
