Author Topic: Perfect day for the air con to not be working  (Read 4339 times)
Offline Mag_Pie
« on: 31 July 2020, 20:08 »
I came to use the air con today and got no cold air  :sad:
Not sure how to describe it but usually when I turn on the air con there is a whoosh type sound which stops followed soon after by cold air. All I’m getting is the whoosh noise permanently.
There is also no click or idle increase when turning the air con on.
Just wondering what to expect when I go to the dealers as it’s still under warranty, will it all be covered even if it’s a basic issue such as low gas?  I’ve had a quick look under the bonnet and can’t see any obvious marks or dribbles.
Offline fredgroves
Re: Perfect day for the air con to not be working
« Reply #1 on: 31 July 2020, 20:15 »
Have you looked at the condenser for stone strikes? The mk7 is generally pretty well protected but it's still possible...
Offline mcmaddy
« Reply #2 on: 31 July 2020, 20:18 »
More to the point why was the climate control off in the first place  :whistle: Never turn mine off.
Offline fredgroves
« Reply #3 on: 31 July 2020, 20:44 »
You haven't got the car in eco mode... That kills the ac
Offline ramrod
« Reply #4 on: 31 July 2020, 23:25 »
i think the dealer would see that as something to charge you over the odds for.. groupon are doing aircon recharge via ATS for about £40 currently
thinking about doing mine....turned my aircon on and it took a few more seconds than instant which caused a minor discomfort :nerd:
Mk6 Gti - current daily
Mk3 16v Anni - retired daily now parked on 200,300 miles
Offline monkeyhanger
« Reply #5 on: 01 August 2020, 08:56 »
If that pressurising whoosh doesn't go away, my money's on a leak. Take it to the dealers. If they deem it to be stone damage then you'll have to pay for that and it's about £700 at dealer rates. If I got that news I'd be going to an Indie for the repair.
Offline Mag_Pie
« Reply #6 on: 01 August 2020, 16:17 »
Thanks for all the advice. At first I remembered that I’d been messing about with the driving mode button so hoped it was in ECO mode. Sadly not, had a look through the grill at the condenser and whilst there are some small dings in the fins (surprised when I looked) there doesn’t look like anything obvious on the actual element bars but that doesn’t rule out anything at this point I guess.
How will the dealer fault find, do they put some sort of dye through the system and see where or if it shows itself?
I hate people messing with my car 😢
Is it a major dismantle job to replace a condenser. The warranty is up at the end of the year, is it a doable DIY job with time and patience?
Offline Mag_Pie
« Reply #7 on: 01 August 2020, 21:28 »
Just been googling and it looks like the entire front end has to come off, is that true :cry:
Doesn’t look like an overly expensive part, I guess it’s the labour.
Offline fredgroves
« Reply #8 on: 01 August 2020, 21:54 »
Was about fifteen hundred quid on my insignia when that got a stone hole....
Offline Mag_Pie
« Reply #9 on: 01 August 2020, 22:08 »
Ouch, might have to open the windows for a while.
