Author Topic: Factory number plate surround - front  (Read 7342 times)
Offline Ceefeesh
Re: Factory number plate surround - front
« Reply #10 on: 23 July 2020, 19:54 »
I put my number plate on with a frame called a Denzofit which is a very thin surround popular in Germany. I bought it on Amazon but they haven’t had them on sale for a while. It mounted into two of the VW holes and the number plate clips into it secured by 10 plastic clips that are part of the surround. Plates are a doddle to swop into or out of the holder, when you figure it out. The surround is flat but I think it is close enough to the shape of the bumper that it looks fine.
« Last Edit: 26 July 2020, 18:01 by Ceefeesh »
Offline mcmaddy
« Reply #11 on: 23 July 2020, 22:21 »
I've actually got two Wolsberg number plate holders from when I had my Mk5 and the holes in the boot lid were pre drilled and plugged. I might see what that looks like.
Offline Jim_mk7.5
« Reply #12 on: 29 July 2020, 13:53 »
A standard plate will cover all the holes that are left but as you say if putting same plate back on may as well put standard fitting back 👍
Generally only reason to remove the plate holder is when going to a smaller plate etc.
Plus just thought that due to the slight curvature of the bumper (I don't think it's a nicely flat surface) the plate won't sit flush which means more likelihood of it falling off after time. I removed my plate holder off the 3er but only because went short plate and I'm using a removable mounting bracket so when the plate is removed it look cleaner for shows etc.
Cheers, I did wonder about the shape of the front bumper and I'm definitely putting a standard size plate back on.
Take the holder off and have some metal pressed plates made and stick them on. They look so much better than the cheap dealer plates :cool:
NOW - 330e M Sport
Offline mcmaddy
« Reply #13 on: 29 July 2020, 15:04 »
I've had some new plates done by the detailer so just sticking them back on. Might change plates at a later date.
