Author Topic: Golf gtd hesitation..  (Read 2632 times)
Offline johntychwith
« on: 09 July 2020, 07:38 »
Hi there my 2015 manual gearbox Golf GTd  has a bit of a problem as soon as I go to change up Gear with the little icon on the dash telling me to change up it's as if the throttle backs off for you like a bit of a flat spot.. could this be the throttle pedal?
Offline monkeyhanger
Re: Golf gtd hesitation..
« Reply #1 on: 09 July 2020, 07:42 »
Unless you're red-lining and bouncing off the limiter, there should be no hesitation. The message to prompt a gear change is to encourage economical and can be switched off. This message shouldn't coincide with hesitation unless you've hit the limiter with your foot down.
« Reply #2 on: 09 July 2020, 07:46 »
No it's only when really light throttle has been applied like when you're just really lightly changing say from third to fourth really low revs it says if it'll back off the throttle for you
Offline fredgroves
« Reply #3 on: 09 July 2020, 10:11 »
What sort of speed/revs are you talking about?
Is the engine up to normal temperature or is it still cold?
« Reply #4 on: 09 July 2020, 11:49 »
Any operating temperature say when im just cruising quietly and change up when minimal throttle is being used it will back off as if youve completely come off the throttle for a split second. Hard to explain i know...
Offline Watts
« Reply #5 on: 09 July 2020, 12:18 »
Is the car new to you or is this a change to how it used to be? If it has changed, have you changed anything else which may account for it? Do you have the driving mode in Eco? Might be worth having it scanned for fault codes.
Previously:
« Reply #6 on: 09 July 2020, 12:44 »
Sorry yes it had a new timing belt and throttle body installed . Shouldve said that sorry
