Author Topic: Inside rear doors scratching  (Read 1838 times)
Offline CookieMonsterGTi
« on: 21 June 2020, 19:57 »
Wiping down the inside of the rear doors today and noticed (same place on both sides) has a couple of scratches. Very fine but taken the paint off. It’s inline with the botyom edge of the window.
Anyone else noticed this or know what the cause could be (outside of it just rubbing)?  May have to get some clear 3mm for short term to stop it getting worse.
Pure Grey GTI TCR 5 Door DSG
19" 'Reifnitz' Alloys Including DCC
Climate Windscreen
Panoramic Sunroof
90% Rear Tinted Glass
Offline Mag_Pie
Re: Inside rear doors scratching
« Reply #1 on: 21 June 2020, 20:26 »
I've noticed this and would be interested on hearing from others.  I think other than having the dealer take a look (maybe they would mess about and try tweaking the hinges???) 3M tape could be a good shout.
Offline clarky92
« Reply #2 on: 22 June 2020, 10:55 »
I have this, but in the top corners of both rear doors, same on each side.
It hasn't got any worse in just over a year, so I'm guessing the fitment was a tad too tight, and its rubbed the clear coat off enough to clear it now.
« Reply #3 on: 22 June 2020, 14:18 »
I may look for some 3m tape then if you haven't seen it get worse over the last 12 months.  Don't really want to end up needing paint or even consider that at the moment for how much damage is done at this time.
Climate Windscreen
Panoramic Sunroof
