Author Topic: Mk6 GTi - What is this weird noise?  (Read 2830 times)
Offline drokkeh
« on: 27 May 2020, 10:05 »
https://www.youtube.com/watch?v=zaLrl47_zPM
Anyone know.  Been happening last couple of months.  Sometimes can hear it when driving?
Offline Borbus
Re: Mk6 GTi - What is this weird noise?
« Reply #1 on: 27 May 2020, 20:16 »
That actually does sound like the headlight washers. I've only heard mine once which was right after I replaced the blown fuse. It's since blown the fuse again for some unknown reason. You could test the theory by removing the fuse. It's number 36 on the inside fuse box. See: https://fusesdiagram.com/volkswagen/fuses-and-relay-volkswagen-golf-6.html
2010 Mk6 GTI
Offline doberman19
« Reply #2 on: 30 May 2020, 12:33 »
 I think you may find that it's the headlight self levelling  set up, my daughter had something similar,
for no reason her headlights would go up and down for no reason, first point to check would be the levelling switch next to the dash light dimmer these do fail.
Offline drokkeh
« Reply #3 on: 30 May 2020, 13:13 »
Thanks.  That was spot on.  It was the headlights randomly levelling.  I moved it into the 1 position and I can't hear it now.  If it starts up again I will replace it
