Author Topic: Mk7.5 gti - how to make it quieter  (Read 36929 times)
Offline barrym381
Re: Mk7.5 gti - how to make it quieter
« Reply #10 on: 18 May 2020, 12:30 »
Trade it in for an S-Class.
The way they drop in value you could pickup a few year old one  :whistle:
Offline rajb
« Reply #11 on: 18 May 2020, 15:43 »
Never heard of anyone wanting to make their car quiter but that sound dampener is pretty good.
Offline golfdave
« Reply #12 on: 19 May 2020, 20:24 »
If you read the later posts by "Fuelboss", for him to say what he does is quite something. He is over here in UK & created a few websites about the problems on the early MK7 Golf Sachs rear dampers. He also had a few problems with noise from other MK7.5 Golfs & finally has a MK7.5GTI which's he has done loads of sound deadening to etc. As a long shot he tried the damper, not thinking it would do much & was very skeptical..but he's been very surprised!!
When VAG first designed the multilink rear for 2003 MK5 Golf platform (A5 PQ35) it must have found that the subframe had a natural resonance which amplified any noise transmitted through the subframe from the suspension. The engineers then created a "harmonic damper" to cancel out these frequencies in the subframe, by drilling two holes in the subframe & mounting the "balance weight". This part was then given a code starting 1K0 which is the code for the new parts on the MK5 Golf. The part was not put into mass production & first appeared on the MQB platform Audi A3 saloon.
So if all A5 (PQ35) & MQB rear subframes have the two holes drilled for it why was it not fitted until 2013 on the Audi A3??...Bean counters decided not to fit for cheapness on the other cars & the noise was too great on that specific A3 bodyshell for the "premium image" so they fitted it??
Offline Al1040
« Reply #13 on: 22 May 2020, 14:09 »
Having had noise issues with my car, I have gone ahead and ordered the 'harmonic damper' and lock nuts from E-Acca
Item No.6:- 1K0 505 563, Balance weight
Item No.7:- N 901 838 03, Hex collar nut self-locking M8 (A03G)
Just under 64 Euros inc delivery
Will see in a few weeks if it makes any difference.
67 Plate Mk 7.5 GTD DSG
Offline Pretzel
« Reply #14 on: 22 May 2020, 14:54 »
Have you tried anything else to reduce noise levels?
Offline Al1040
« Reply #15 on: 22 May 2020, 15:03 »
Not as yet, at its last service i did complain about the 'rumbling / droning noise' from the rear of the car... to which a wheel bearing was allegedly changed but nothing was noted on the service paperwork and did not appear to make a great deal of indeed any difference.
I will have another go with a local independent at its next service which I will have done just prior to the warranty running out.
Having been reading online, common issues appear to be shocks (mainly MK 7) and VW being stingy on the sound deadening material when they switched from the Mk 7 to 7.5
I also appear to have dissolving lumber padding on the drivers side which I will want looking at. :cry:
Offline Npr
« Reply #16 on: 09 July 2020, 17:02 »
Hi, finally checked my tyre pressure and they were all at 36 or 37 so set them at 36. Have now ordered the parts to have fitted at start of Aug.
AI 1040, did you get yours fitted? Did it reduce the road noise?
Just to clarify some earlier posts- it's the road noise that bothers me. I would like to hear the engine and exhaust more.
But the road noise on some surfaces at 50-70 mph is unacceptable.
Offline Al1040
« Reply #17 on: 09 July 2020, 18:03 »
Hi NPR,
I have not fitted yet, they have not arrived... My fault the payment did not go through, only found out when I was checking up on the delivery :embarrassed:
Should be here in a couple of weeks :smiley:
Offline Hertsman
« Reply #18 on: 10 July 2020, 09:53 »
You could make it into a TCR Caddy?
Know this is off topic but had to plonk it somewhere as stumbled on this today and the things folk do  :smiley:
https://www.facebook.com/vagcarsedition/photos/pcb.3063195403771555/3063195173771578
Present - Cupra Terramar 272BHP VZ1 - Fjord Blue
- 2nd car: 2019 Golf R DSG Pure White 19" Black Pretoria, Privacy Glass, Rear View Camera, Dynaudio, Keyless
- 2022 BMW 128Ti Alpine White
- 2019 Pure Grey GTI TCR 5 Door DSG Reifinitz Wheel DCC Climate Screen 90% Tint
- 2016 Lapiz Blue Golf R 5 Door DSG Pretoria DCC
- 2013 Pure White GTD 5 Door DSG DCC
Offline p3asa
« Reply #19 on: 10 July 2020, 12:06 »
I have to admit, that's impressive.
