Author Topic: Is rust becoming a common problem ?  (Read 13425 times)
Offline Rob_benton
« on: 28 April 2020, 22:17 »
Hi
After reading the PistonHeads review, a couple of owners mentioned rust on the sills and arches and I’m sure someone had issues too on this forum, is this becoming more regular now mk7’s are getting on ?
Has anyone else noticed rust appearing ?
I’m going to give it a thorough check but I haven’t noticed anything yet.
2014 gti pp dsg
Offline Watts
Re: Is rust becoming a common problem ?
« Reply #1 on: 28 April 2020, 23:20 »
I've not heard of any rust issues on here, but given how the paint can chip so easily I can imagine "hidden" areas (to those that may not pay much attention to) could easily go through to bare metal leading to surface rust. But that could happen to any car. Anyone who regularly tends to their car should spot potential issues in plenty of time and with a bit of effort avoid them becoming a problem.
Previously:
Offline Lordie
« Reply #2 on: 28 April 2020, 23:38 »
One of the best things you can do is wash your own car. Will find things you've never noticed before
Offline Watts
« Reply #3 on: 28 April 2020, 23:56 »
Very true, perhaps a little more often than I've managed recently though....
Previously:
Offline zxrmatt
« Reply #4 on: 29 April 2020, 09:22 »
I imagine it will be with front wings and the big piece of foam on the inside - the foam has caused issues with previous golfs.
This would be the main place i would check first, around the inside and bottom of wings and sils
Offline Rob_benton
« Reply #5 on: 29 April 2020, 10:46 »
Do mk7’s have foam still in the front wheel arches ? Surely not !
2014 gti pp dsg
Offline SRGTD
« Reply #6 on: 29 April 2020, 10:53 »
^This - any damage can be spotted and dealt with early. One of the first things I buy when I get a new car is a paint touch up kit - often bought before I get the car, to deal with the inevitable stone chips as and when they happen.
With a modern car though, I think I’d be more concerned about mechanical and electrical failures than the likelihood of corrosion.
The mk6 Golf had foam inserts where the front wings were joined to the car body shell near the door hinges. I never had any issues with corrosion on my mk6 in this area (or anywhere else for that matter) in nearly 5 years of ownership, in spite of this foam insert getting wet regularly. Come to think of it, I can’t remember seeing a rusty mk6, so assuming the mk7 body shell and panels get the same level of corrosion protection as the mk6 did, if the mk7 has a similar foam insert piece in the same location, I wouldn’t expect this as major source of corrosion on the mk7.
Corrosion on the sills is usually the result of the flexible anti-stone chip coating becoming damaged around the jacking points as a result of careless use of trolley jacks by tyre fitters. I always check the edges of my sills for damage after having tyres fitted, or after servicing / MOT and repair work to ensure the anti-stone chip coating hasn’t been damaged.
Gone but not forgotten;
2016 Polo GTI; Blue Silk
Offline Phil245
« Reply #7 on: 29 April 2020, 11:09 »
Absolutely.
I am so OCD about this that I take the wheels off myself at home and take them in another car to the tyre shop for them to fit & balance the new tyre......
2019 Golf GTI 245 Performance, 2020 Skoda Karoq Sportline 2.0 TDI
Sadly sold, Octavia VRS245 Estate, Audi A3 1.5TFSI S Line Black Edition, Polo GTi 1.8, Audi TT Roadster, Golf Mk7 GTD etc.
Daughter has 2019 Polo 2.0GTi DSG. We love VAG !
Offline Burger81
« Reply #8 on: 04 May 2020, 07:56 »
I'm the lucky one who was talking about my rust on piston heads!
I was going to post on here but couldn't upload pictures of my car.
My patches were on both sides on the front wing on the underside of the gap between the door and lower sill), and at the back low down before the wheel arch where there was bubbling under the paint (this is the bit that VW wouldn't fix under warranty as they deemed it to be caused by an "external influence").
This bubbling is still to be fixed and hasn't got any worse (probably 7 months after first finding it too).
The patches they did fix they only did the affected area, I thought they might just replace the wing it was on!
I have slightly wider wheels on my car than standard so I was worried about pushing VW too hard in case they blamed that.
My whole argument was that it doesn't matter what initially caused it to bubble, as a car under 3 years shouldn't be rusting anyway. I have stone chips on the bonnet that haven't rusted!
The warranty guy who did the report said that according to his file on rust issues that it matched galvanising issues from his experience. But VW didn't agree with him, nor did the independent inspector who came out (though he came through VW).
All a bit of a sour experience to be honest.
Offline barrym381
« Reply #9 on: 04 May 2020, 11:30 »
@burger81 just keep on at them I had similar issues with Audi a few years ago with my roof on our s3 they tried to blame a stone chip although there was no visible chip
