Author Topic: Discover Nav music on SD card  (Read 6090 times)
Offline fredgroves
Re: Discover Nav music on SD card
« Reply #20 on: 16 April 2020, 18:52 »
I'm maybe looking at a SSD drive to plug straight into the usb port. Small one obviously 😂
Might not work TBH. You can get funnies with those because they are slightly different to a memory stick at a low level.
The biggest SD card you can buy would surely be enough music anyway wouldn't it? You can get up to 1tb now (not sure if the car would support one that big mind you!)
Its not like its permanent anyway, you can always swap albums around - I do!
Offline ajmoir36
« Reply #21 on: 16 April 2020, 19:07 »
I use a 512gb sdxc card no issues with my 2019 Nav. Other than the 30k track limit. 10k to a folder. I set it out in an A-Z fashion the albums under that. To mix albums you just need a track in the root of the say A folder to mix the A albums.
Diagonally parked in a parallel universe.
On Order: Mk8 R, Pure White, Reversing Camera, Harmon Kardon, Heated seats all round.
Gone: Mk7.5 R, 5dr, DSG, Deep Pearl Black, 18” Cadiz, Nav, Winter Pack, Keyless, Dynaudio and Reversing camera.
Gone: Mk7 R, 5dr, DSG, Limestone Grey, 19" Pretoria's, Nav Pro, DCC, Winter Pack, Keyless, Mobile Prep and Reversing Camera.
Gone: Mk6 GTD, 5dr, Manual, Tornado Red, 18" Vancouvers, RCD510 + Dynaudio, heated seats.
