Author Topic: Ctek 5.0 charger recon mode ?  (Read 2841 times)
Offline Rob_benton
« on: 30 March 2020, 13:21 »
As I won’t be using the car for a while I thought I’d hook up the charger to charge the battery.
Does anyone ever use recon mode that is supposed to move around the acid to prolong the battery life once a year?
Also do you use normal mode or agm ?
Thanks
2014 gti pp dsg
Offline funboxster
Re: Ctek 5.0 charger recon mode ?
« Reply #1 on: 30 March 2020, 18:50 »
As I haven't used the car for 2 weeks, and it could be a while yet, I hooked my TCR up to the CTEK MX5. It automatically switched to normal battery programme(car symbol) and AGM, at level 3. Pressing the Mode switch made no difference.  Just checked it and it's sitting at 7 (float) so good news.
Pure White MY 2020 GTI TCR 19" Reifnitz with DCC, Pan Roof and Climate Windscreen
Offline Rob_benton
« Reply #2 on: 30 March 2020, 20:05 »
My battery is an EFB, investigation Says to charge on normal.
Only concern is recond charges at a higher rate to do its job and some forums say it can damage the electrics unless you disconnect the battery which I don’t fancy doing.
2014 gti pp dsg
Offline Rob_benton
« Reply #3 on: 01 April 2020, 09:11 »
For future reference. Finally heard back from ctek and they say it’s fine to recond a EFB battery while it’s connected to the car.
2014 gti pp dsg
Offline Pretzel
« Reply #4 on: 01 April 2020, 09:40 »
Assuming the battery is in good condition, does anyone know how long the car can stand unused before we get problems?
Offline Rob_benton
« Reply #5 on: 01 April 2020, 09:49 »
Tough one as every battery’s life is different. A few owners have had Vw batteries replaced very early in their life.
I’m going to start my car every 4-5 days and get it up to temperature and move it to stop rust on the discs which can cause problems down the road. I have a very long private drive 😂
2014 gti pp dsg
Offline mcmaddy
« Reply #6 on: 01 April 2020, 12:21 »
I've just left mine locked but in reverse with the hand brake off.
Offline Rob_benton
« Reply #7 on: 01 April 2020, 14:23 »
I’m do this too but I’ve seen cars with built up rust on the discs and the discs never cover. It’s probably after sitting in the rain for 6 months but I am a bit ocd.
2014 gti pp dsg
