Author Topic: Cracked sunroof surround  (Read 190089 times)
Offline madstaff
Re: Cracked sunroof surround
« Reply #200 on: 24 April 2022, 12:11 »
I’d consider getting the sunroof surround vinyl wrapped if it happened out of warranty; it’d be significantly cheaper than paying for VW to replace it.
There are cases of cracked sunroof surrounds on older mk7 Golfs reported by forum members over on golfmk7.com forum, and also instances of the glossy top layer of the sunroof surround delaminating / peeling.
Yes, that would be a potential fix, bit of silicone or Araldite into the gap first to keep the water and dirt out.
I would dread to guess how much a replacement at VW would cost??
Offline Watts
« Reply #201 on: 24 April 2022, 18:36 »
The surround is near £600, at least that was what was on the invoice when mine was done. Plus fitting. So I'd guess around £1k all in.
Previously:
Offline madstaff
« Reply #202 on: 24 April 2022, 20:32 »
I would imagine £400 at VW isn't buying you many hours of labour though, and I can't see repairing that is a morning's work??
Interested to know the VW repair time for this.
« Last Edit: 24 April 2022, 20:43 by madstaff »
Offline Watts
« Reply #203 on: 24 April 2022, 21:12 »
VW don't do it, they get a windscreen fitter in.
Previously:
Offline Kpow99
« Reply #204 on: 26 April 2022, 16:11 »
That’s what they said to me too! Doesn’t take long but needs setting time.
2019 TCR, Pure Grey, DCC/PP Revo Stage 1
Offline Markee
« Reply #205 on: 04 June 2022, 11:24 »
I had read this thread not long after i bought my TCR and thankfully i'd not experienced anything like you guys have with the cracking. However yesterday when parking in a grass field at a car show i experienced my sunroof making cracking/creaking noises! It is fine on normal roads and i've not noticed it on twisty roads (that might change when i'm in Cornwall next week!). A quick nosy around the internet seems to put it in the same fault bracket as the cracking roofs, hence why i've not started a new thread.
Obviously this has set alarm bells ringing and i'd like to get VW to take a look but i'd also like to go armed with info in case they give any push back, i've seen screenshots etc of it being a known fault by VW but can find a definitive tech bulletin admitting it or the rectification for it. I'm hoping that VW might be a little more accepting under warranty in that mine doesn't need replacing, only removing and resealing correctly (from what i've read the fault is down to the sealant?) but at the same time i'd like proof that they are aware of the issue.
A chequered previous car history (mainly blue oval, sorry) prior to owning Golf's.
2001 mk4 TDI - died at some traffic lights due to someone not stopping!
2000 mk4 GTD - a dog of a car, sold to WBAC in limp mode!
2000 mk4 1.8T - most fun i've had in a Golf (until now) but nearly cost me my licence!
2020 mk7.5 Tornado Red TCR - current ride.
Offline SRGTD
« Reply #206 on: 04 June 2022, 12:11 »
If it was creaking rather a cracking sound, it could have been the door seals rubbing against the door openings. The seals tend to dry out over time and when they do they creak when the car’s bodywork flexes (normal), as it would be likely to do if you were driving off road at the time.
If it was your door seals, then you could lubricate the them with a product such as Gummi pflege or VW’s (very expensive) Krytox which should stop the creaking.
If you do a Google search on VW creaking door seals, you’ll see it’s pretty common and experienced by many owners.
Gone but not forgotten;
2016 Polo GTI; Blue Silk
Offline Watts
« Reply #207 on: 04 June 2022, 14:32 »
The sunroof does creak which can be sorted by lubrication as per the door seals as SRGTD says. There is also a sunroof service for about £100 which will clean and lubricate the mechanism. The lubricant, Krytox, was for the Eos model's folding hardtop afaik which creaks too. I've not heard of a fault with the roofs involving noises due to lack of sealent.
Previously:
Offline Markee
« Reply #208 on: 04 June 2022, 18:37 »
One person's creaks is another person's cracks lol, i guess what i interpret as a crack someone might think it's a creak. I know it's hard to pinpoint noises down in cars and initially i thought it was further back in the car, almost in the the parcel shelf area, then when it happened again the missus thought it came from the sunroof. It happened a few times more and on leaving the show and i was pretty certain it was coming from the rear of the sunroof! I'll take a punt with some Gummi pflege and get busy on the seals up top and doors and see if that cures it.
I'm an over-thinker so have probably looked at too much crap about it and got crossed wires somewhere along the lines  :laugh:  If i was to try and describe the sound it would be like two bits that have seized together being unseized, just on numerous occasions. Similar i guess to your discs and pads seizing if the car has been sat unmoved for a long time.
If i'm honest i've never been one for sunroof's and if mine didn't have one i'd have been more than happy, that said having a sunroof was never going to stop me buying it!
Offline Watts
« Reply #209 on: 04 June 2022, 22:14 »
I think if it was going to crack, it would've done so. Do think that you were going over rough ground and the shell is going to flex. Hopefully it'll settle down but the door seals and sunroof seals do need regular lubrication to keep them quiet. If I were you, get some Krytox, it might be more expensive but a little goes a long way and it lasts longer than the alternatives so it's a better bet in the long run.
Just to add, my roof creaks and groans now and then but I love having it and open it up lots, I'm very happy with it!
Previously:
