Author Topic: Dynamic Cornering Light Fault  (Read 4263 times)
Offline jaceyboy
« on: 25 February 2020, 20:57 »
Just had this pop up tonight, does it mean the bulb has blown?, if so does anyone know what type of halogen they use and how easy to change?, cheers
MK7 GTi
Offline Rob_benton
Re: Dynamic Cornering Light Fault
« Reply #1 on: 25 February 2020, 21:03 »
Yes mine was blown
2014 gti pp dsg
Offline jaceyboy
« Reply #2 on: 26 February 2020, 09:53 »
Ok thanks, doesnt say which side
MK7 GTi
Offline Watts
« Reply #3 on: 26 February 2020, 10:19 »
I bought GE H7 477 from Halfords at £19 a pair. Very easy to fit, especially compared with changing the headlight bulbs!
Previously:
Offline Finglonga
« Reply #4 on: 26 February 2020, 10:26 »
Put it reverse next to a wall or when dark and you will se the bulb that has blown. They are H7 bulbs, I use LED's as they are much brighter.
« Last Edit: 26 February 2020, 10:36 by Finglonga »
Offline monkeyhanger
« Reply #5 on: 26 February 2020, 10:58 »
There aren't road legal H7 LEDs though, are there?
With cornering lights doubling up as fog lights, crisp white LED light is much less penetrative through fog than yellow halogen light.
Offline Finglonga
« Reply #6 on: 26 February 2020, 11:56 »
Not on the lighting package they are completely separate to the fog lights. The cornering lights are in the headlight unit. They have been LEDs for 5+ years now with no problems and the beam pattern is the same as the oem bulbs and don't blow as often as halogen ones.
Offline jaceyboy
« Reply #7 on: 26 February 2020, 15:15 »
It was the passenger side that had gone, so have replaced it but might look into the more blue light ones...
MK7 GTi
