Author Topic: ESP fault  (Read 3780 times)
Offline roblyt
ESP fault
« on: 11 February 2020, 22:30 »
 just wondering if anyone else has had this issue
ive got an ESP fault light on now,it stays on and doesn't go off :angry:
its giving a fault code of p0122 which will not clear
the car seems to be running perfectly fine with no issues at all that im aware of other than the fault light being on
anyone else experienced this?
Offline jv
  • Administrator
Re: ESP fault
« Reply #1 on: 12 February 2020, 07:49 »
Searched the code? All seems to be throttle pedal position sensor related.
Buy site stuff!
GolfGTI.co.uk - merchandise
Support the forum charity!
Offline roblyt
Re: ESP fault
« Reply #2 on: 12 February 2020, 10:16 »
yeah seems so, I just googled it
it was in the garage being serviced yesterday, they checked the code out but couldn't give me a definitive answer to what it was.it was only booked in for service though so don't know how much time they spent on the fault code
Ive got to take it back in when the auto electrician is in
quick google search does seem to point to tps being the common problem
Offline topher
  • Administrator
  • fully functioning
Re: ESP fault
« Reply #3 on: 12 February 2020, 23:10 »
there is a technical bulletin from VW for this fault on the 2,0 tsi engine, which involves replacing the connector and pins/repair wires for the throttle body. The pins lose tension over time and cause excessive resistance which triggers the code. I've done this very repair many times and even did it on a scirocco earlier today. Parts are around £20 and takes roughly 30 minutes.
Offline roblyt
Re: ESP fault
« Reply #4 on: 13 February 2020, 11:04 »
cool, thanks for the info topher
ill look into that when I get chance
hopefully that's the issue :smiley:
