Author Topic: Fault code on Golf bluemotion tdi.  (Read 3794 times)
Offline AudiA8Quattro
« on: 02 February 2020, 13:19 »
One of the guys that works for me has the code P2563 on his Golf.
Turbocharger Boost Control Position sensor circuit - implausible signal.
It’s an intermittent fault, but does seem worse when the car isn’t being used much.
Also the glow plug light flashes.
The car is a bluemotion 1.6 tdi, I think, 2010 plate.
Will this be down to clogged veins on the turbo? Or the actuator sticking? Or something else?
Thanks in advance..
Offline Snoopy
  • Moderator
  • Geoff.
Current Garage:
35+ years of GTI ownership.
Re: Fault code on Golf bluemotion tdi.
« Reply #2 on: 13 February 2020, 23:14 »
Thanks for the reply, will look into it!
Offline topher
  • Administrator
  • fully functioning
« Reply #3 on: 14 February 2020, 01:33 »
first thing to check on these is that the actuator is holding vacuum. ideally use a mityvac or similar but good old lung power with a bit of vac hose works too. depending on the turbo thats fitted the actuator can usually be replaced separately
