Author Topic: Carista - available options  (Read 25475 times)
Offline wrighty79
Re: Carista - available options
« Reply #40 on: 29 April 2020, 11:37 »
You need to enable the option to display on the car menu - that’s a Carista mod found in the same section.
I have the beep on alarm but it never put a menu in my infotainment to alter settings of it?
Offline Mutley75
« Reply #41 on: 29 April 2020, 14:48 »
I think there's some inconsistency between cars.  For example a mate's car shows the yellow air flow lights on the temperature dial even when the aircon is set to Auto, whereas mine was off.  Both were 2019 factory orders, so not all GTIs appear to come with exactly the same settings from the factory....
Golf GTi Performance Edition (2019), 5dr, DSG in Isaac Blue, Dynaudio & Brescia alloys.
Offline wrighty79
« Reply #42 on: 29 April 2020, 15:13 »
that would explain it then, I have the beta testing n tried loads of times to get the colour changing on digital dash n info unit n the menu just would appear at all even if I reset the unit!!
Offline Vwjap
« Reply #43 on: 02 May 2020, 16:49 »
That’s why I prefer obdeleven as you can see what your changing, I liked the colour change but people were complaining that you couldn’t have independent brightness control, luckily I had access to a car that did and found the difference, then went in and changed it and got the job done, I dunno if Carissa you can do this tho
Offline Mutley75
« Reply #44 on: 02 May 2020, 16:53 »
Yes you can. And you can see what you’re changing.
For example - https://images.app.goo.gl/cPidCioKAKNX4cDV8
Offline Vwjap
« Reply #45 on: 02 May 2020, 20:54 »
No that’s just what script you’ve set/unset, something like the 10 colour mod has 15 different switches to change via coding inside the actual module, plus another 4 if you want independent brightness, the screen you posted is just like a list of apps from obdeleven, it doesn’t show the actual switches your changing, if you get my drift
Offline wrighty79
« Reply #46 on: 05 May 2020, 13:40 »
im on beta n my menus don't have half of them options in some of them pics!!
Offline Mutley75
« Reply #47 on: 05 May 2020, 17:06 »
It was a sample picture from Google Images to show what the Carista screen looks like.  Those menus were for a different variety of car brands.  Refer to the first page of this thread for all available options.
« Last Edit: 05 May 2020, 17:08 by Mutley75 »
Offline Popinman
« Reply #48 on: 04 May 2021, 07:39 »
Hi guys. Anyone know if you can code out the “apply park brake when you open driver door” using Carista (Mk7.5)? I’m pretty certain it’s not listed anywhere, but I’m hoping I’m missing it and you can…..
Really drives me mad when I’m parking, sometimes need to open my door to check alignment of the car, and the parking brake then applies itself….. :angry:
Thanks!
2018 GTi PP Indium Grey
Offline Mutley75
« Reply #49 on: 04 May 2021, 07:51 »
I don’t think you can. But if you turn off the Auto Hold (the button behind the parking brake) it won’t do it.
