Author Topic: Carista - available options  (Read 25473 times)
Offline Mutley75
« on: 08 January 2020, 21:40 »
For those who are interested, I have noted down each available customisation option on the Mk 7.5 GTI.  I've only listed the top level menus and not all of the options/sub-menus as there are quite a lot, but you get the general idea.  Bare in mind, some of these options are already enabled by default for the GTI.  The app can configure lesser model Golfs which may not have these options on the dash display.
Chassis & Engines
  - Disable auto start/stop system
  - Soundaktor volume
  - Power steering default mode
  - Throttle response behaviour
  - ESC/ASR
Dings & Warnings
  - Seat belt warning
  - Speed warning at 75mph
  - Ding when key left in ignition
Driver Assist
  - Dynamic start assist
  - Hill start disengagement
Heater & A/C
  - Remember recirculating air state
  - Show A/C blower speed when in Auto
  - Temperature adjustment for hot countries
Instruments: Display & Nav
  - Gauge needle sweep at startup
  - Developer menu in MMI holding Menu button for 10 seconds (Discover Pro only)
  - Start screen logo (infotainment)
  - Start screen logo (instrument cluster)
  - Microphone sensitivity
  - Driver information system (DIS) display
  - Allow enabling oil temperature display via MMI
  - Oil temperature display
  - Efficiency program display
  - Refuel quantity in MFD
  - Telephone menu display
  - Battery charge display
  - Navigation compass display
  - Compass display position
  - Ambient temperature display
  - Allow 'Car' settings in MMI while car is in motion
  - Allow 'Tuner' settings in MMI while car is in motion
  - Allow 'Media' settings in MMI while car is in motion
  - Allow 'Phone' settings in MMI while car is in motion
  - Show 'Follow traffic regulations' disclaimer in infotainment
Instruments: Language & Units
  - Time display format
  - Date display format
  - Temperature display units
  - Distance display units
  - Speed display units
  - Consumption display units
  - Pressure display units
  - Volume display units
Lights: Coming/Leaving Home
  - Coming home lights
  - Coming home lights mode
  - Coming home lights use...
  - Coming home lights duration
  - Leaving home lights step 1/2
  - Leaving home lights step 2/2
  - Leaving home lights duration
Lights: Daytime Running Lights (DRL)
  - Daytime running lights
  - Allow configuring DRLs via dash display
  - Scandinavian DRL (activate taillights and parking lights)
  - Turn off DRLs when parking brake is on
  - Parking light activates DRLs
  - DRLs on only when switch is set to Auto
Lights: Exterior
  - Lane change turn signal auto-flasher
  - Lane change turn signal auto-flasher count
  - Auto headlights activation threshold
  - Turn off front fog lights when high beams are on
  - Flash rear fogs along with flash-to-pass when headlights are on
  - Flash rear fogs along with flash-to-pass when headlights are off
  - Flash brake lights in emergency stopping
  - Flash brake lights in emergency stopping phase 2
  - Flash hazard lights in emergency stopping
  - Puddle lights driver side
  - Puddle lights passenger side
  - Puddle lights while driver-side mirror is folding
  - Puddle lights while passenger-side mirror is folding
  - Left cornering light (using front fog)
  - Right cornering light (using front fog)
  - Cornering lights activation
Locking: Automatic
  - Auto-lock doors when moving
  - Auto-unlock doors when key is taken out of ignition
  - Auto-unlock doors when shifting into park
  - Car lock and trunk lid close (and lock) via easy close button
Locking: Beep & Blink
  - Allow configuring beep when locking/unlocking
  - Beep when locking with remote
  - Beep when unlocking with remote
  - Menu for configuring beep when locking/unlocking
  - Beep when locking/unlocking doors comes from the... (choose from Alarm or Horn)
Locking: Smart Key (KESSY)
  - Auto-lock when doors are closed and smart key is outside vehicle (step 1/2)
  - Auto-lock when doors are closed and smart key is outside vehicle (step 2/2)
Mirrors
  - Allow auto-folding mirrors
  - Auto fold side-view mirrors
  - Allow configuring auto-folding mirrors on dash
  - Auto-fold mirror via...
  - Allow lowering passenger-side mirror when in reverse gear
  - Lower passenger-side mirror when in reverse gear
  - Menu for lowering passenger-side mirror when in reverse gear
  - Synchronous mirror adjustment menu on dash
Parking Sensors
  - Park distance visualisation
  - Beep when parking sensor activated
  - Rear parking sensor beep volume
  - Rear parking sensor beep tone
  - Front parking sensor beep volume
  - Front parking sensor beep tone
Seats & Steering Wheel
  - Auto-activate steering wheel heater
  - Remember driver-side seat heater level
  - Remember passenger-side seat heater level
Trunk
  - Pop trunk via remote
Windows & Sunroof
  - Enable setting for opening/closing windows and sunroof
  - Allow configuring open/close windows with remove via dash menu
  - Open windows via long-press on remote (step 1/2)
  - Open windows via long-press on remote (step 2/2)
  - Close windows via long-press on remote (step 1/2)
  - Close windows via long-press on remote (step 2/2)
  - Open sunroof via long-press on remote
  - Close sunroof via long-press on remote
  - Sunroof action when opening via remote
  - Blink turn signals when done closing windows via remote
  - Allow power window operation after ignition is turned off
Wipers & Washer
  - Speed dependent windshield wiper speed
  - Headlight washer activation delay
  - Activate headlight washers once every x times the windshield washer is used
Other
  - Windshield heater runs for duration of x minutes
  - Rear window heater runs for duration of x minutes
  - Enable remote control buttons when ignition is on
« Last Edit: 09 January 2020, 22:44 by Mutley75 »
Golf GTi Performance Edition (2019), 5dr, DSG in Isaac Blue, Dynaudio & Brescia alloys.
Offline Talk-torque
Re: Carista - available options
« Reply #1 on: 08 January 2020, 22:12 »
Seems like a bargain, as you said in your other post. Is it easy to use and does it seem reliable, given that a major screwup of the car's system would be very easy.
Roger.
Offline Mutley75
« Reply #2 on: 08 January 2020, 22:15 »
Yes, you just plug it into the ODB port located under the dash above the pedals. Then you open the Carista app on your phone which automatically pairs with the dongle via Bluetooth. As soon as it’s connected you’re given a simple menu to select your options & simply click save to apply. If something doesn’t work as expected, simply change it back again.
Here’s a short clip showing one option being set:
https://youtu.be/hVEbry6MXfw
« Last Edit: 08 January 2020, 22:20 by Mutley75 »
Offline Rob_benton
« Reply #3 on: 09 January 2020, 10:02 »
Is there anything Carly can do coding wise that Carista can’t? Thanks
2014 gti pp dsg
Offline Talk-torque
« Reply #4 on: 09 January 2020, 11:41 »
Thanks Mutley, all good then. Have all your changes been successful?
Roger.
Offline Mutley75
« Reply #5 on: 09 January 2020, 12:53 »
They have indeed!  Re Carly - I’m not familiar with that so can’t compare the two I’m afraid.
Offline Rob_benton
« Reply #6 on: 09 January 2020, 14:10 »
I’ve just activated the chirp when locking my car, it said I need to activate it in my infotainment menu but I can’t find it ?
Thanks
2014 gti pp dsg
Offline Mutley75
« Reply #7 on: 09 January 2020, 14:27 »
You need to enable the option to display on the car menu - that’s a Carista mod found in the same section.
Offline Rob_benton
« Reply #8 on: 09 January 2020, 14:51 »
Done it thanks
2014 gti pp dsg
Offline Rob_benton
« Reply #9 on: 09 January 2020, 17:20 »
I’m struggling to find out what ‘ Dynamic start assist’ is ? Is it worth playing with ?
2014 gti pp dsg
