Author Topic: Idea: Mk2 door pockets adapted for 6.5" components  (Read 1287 times)
Offline j_s
« on: 14 October 2005, 11:58 »
I'm looking into adapting my own but they will look factory supplied when i've finished, i.e plastic sort of bump affect just like the rest of the door pocket. If I could get them made up quick enough who else would be interested in this, either on a pair of door pockets supplied from me or you send your own to me for adaption. The only thing you would need to do is run speaker cable into doors (so easy to do) and make a hole behind where the speaker sits in the door card, oh and obviously remove/add door pockets. The cost is yet to be determined but will be a bargain compared to Audioscape ones and I would probably charge cost of materials + a little for my work, oh and p+p (actual cost not stupidly inflated p+p)
This is only a maybe and depends on sourcing the right materials (definitely available in the USA but maybe harder to find over here).
They won't be as solid as Audioscape ones but for £180 you expect them to be solid as those don't use the existing door pockets.
Let me know what you think.
James
Offline jv
  • Administrator
Re: Idea: Mk2 door pockets adapted for 6.5" components
« Reply #1 on: 14 October 2005, 12:53 »
It's a good idea but I think you will need to make a set as an example before people will be prepared to put down money for them :)
Buy site stuff!
GolfGTI.co.uk - merchandise
Support the forum charity!
Offline j_s
« Reply #2 on: 14 October 2005, 13:17 »
I will be doing that jv  :smiley:
I'll give some to Joe to try and any other locals, i'll run them myself as well until I build my proper door builds which require a hack and slash at the doorcards.
Would you want a pair to try jv?
James
Offline jv
  • Administrator
« Reply #3 on: 14 October 2005, 13:25 »
Yeah sure. Will they use the existing mounts? No extra holes required in the door panels?
Buy site stuff!
Offline j_s
« Reply #4 on: 14 October 2005, 14:05 »
Everything should be exactly the same apart from cutting a hole in the doorcard behind the speaker to allow the door to be used an enclosure.
James
Offline ...joe
« Reply #5 on: 14 October 2005, 18:52 »
sounds good mate! i'm sure i could help you try out a set! :P
mail@trimdeluxe.co.uk
www.facebook.com/Trimdeluxe
