Author Topic: Knocking Noise  (Read 7913 times)
Offline ChrisTCR
Knocking Noise
« on: 27 November 2019, 11:32 »
Hi all,
I currently have a GTI TCR, which has been great apart from a knocking or rattling noise coming from the cabin. Best I can tell its on the drivers side in the rear somewhere.
Before I go to the bother of taking it to the dealer has anyone else had a similar noise and been able to track it down and fix it? I would rather do this than go to the trouble of driving to the dealers.
Thanks,
Chris
Offline SRGTD
Re: Knocking Noise
« Reply #1 on: 27 November 2019, 12:03 »
The seat backrest catches / latches are known to rattle on some cars. This was also an issue on the mk6 Golf. If you lower the seat backrest and the noise stops, then that’s the likely source of your noise.
There’s a cheap and easy DIY fix to stop the rattling noise. If you lower the rear seat backrest and wrap some electrical insulating tape around the metal loop that the backrest catch latches onto, it removes any ‘slack’ between the metal loop and the catch, and stops the noise when the backrest is raised again and secured in the upright position.
I had this on my mk6 and the above fix worked. If you regularly raise and lower your rear seat backrest and the tape starts to wear through, its cheap, quick and easy to replace it with some more tape. My initial repair never needed re-doing in the (nearly) five years I owned my mk6 though.
Gone but not forgotten;
2016 Polo GTI; Blue Silk
Offline Hertsman
Re: Knocking Noise
« Reply #2 on: 27 November 2019, 12:37 »
Hi all,
Thanks,
Chris
You not having much luck with cabin noise are you! across the two main forums of GTI and VWROC there is very little posting to cabin rattles, some, but not many and being in my 7th year of MK 7 ownership the only rattle had that had no idea where was coming from for a few days, was from my sunglasses in the overhead cubby hole.
Reason state that this issue is not historic or endemic on the model is to provide some confidence that once identified its likely a simple and easy fix such as a rear seat catch or maybe a passenger even leaving something in the door pocket
Might be an idea to have someone sit in the back as you drive as they can really pick out the source
Be interesting to see what actually is the root cause
Present - Cupra Terramar 272BHP VZ1 - Fjord Blue
- 2nd car: 2019 Golf R DSG Pure White 19" Black Pretoria, Privacy Glass, Rear View Camera, Dynaudio, Keyless
- 2022 BMW 128Ti Alpine White
- 2019 Pure Grey GTI TCR 5 Door DSG Reifinitz Wheel DCC Climate Screen 90% Tint
- 2016 Lapiz Blue Golf R 5 Door DSG Pretoria DCC
- 2013 Pure White GTD 5 Door DSG DCC
Offline ChrisTCR
Re: Knocking Noise
« Reply #3 on: 27 November 2019, 12:43 »
Hi all,
Thanks,
Chris
Tell me about it, PITA.
Offline ChrisTCR
Re: Knocking Noise
« Reply #4 on: 27 November 2019, 12:44 »
Cheers, I will try this. Funny enough I had that problem on my S3 and this fixed it.
Offline Ryan90GTI
Re: Knocking Noise
« Reply #5 on: 27 November 2019, 12:53 »
I had a rattle in mine but a trip to the dealer sorted the problem, turns out it was something to do with a clip for the lights in the sun visor. Never thought it would have been that as I was convinced it was coming from the passenger side door card. Always worth a quick visit to the dealer's first IMO.
Offline Hertsman
Re: Knocking Noise
« Reply #6 on: 27 November 2019, 13:36 »
Noise is a strange thing in pinpointing the direction, I honestly did not even think it was my sunglasses, was convinced it was the glove box, or on the passenger side door, the window etc, but it was sunglasses in an awkward position and so rattled,
Like said, worth having someone else listen while driving and agree with the above, as a complete time saver go to the dealer who should be pretty up to speed with the MK 7/7.5 nuances.
Offline Finglonga
Re: Knocking Noise
« Reply #7 on: 27 November 2019, 14:05 »
Just fixed a knock on mine, sounded like suspension but it was the centre plastic nut had come loose on the spare wheel fixing. Tightened it up and it is silent again.
Offline ChrisTCR
Re: Knocking Noise
« Reply #8 on: 27 November 2019, 16:57 »
I can see why dealers hate these, could be coming from anywhere by the sounds of it.
Offline Talk-torque
Re: Knocking Noise
« Reply #9 on: 27 November 2019, 16:59 »
The rattle on mine was from a plastic cover piece, under the steering wheel, above where your knees are. It is meant to be fixed by a locating tongue at one end and a screw at the other. The screw was fitted, but the tongue end was just hanging loose, so it rattled. Easy to fix.
Roger.
