Author Topic: Looking for Led boot light recommendations  (Read 7447 times)
Offline Rob_benton
« on: 23 November 2019, 12:03 »
Hi
I’m looking for a led boot light, I’ve seen a couple on eBay and Amazon but can anyone recommend what they brought ?
Thanks
2014 gti pp dsg
Offline Mutley75
Re: Looking for Led boot light recommendations
« Reply #1 on: 23 November 2019, 22:23 »
This will do the trick
https://www.amazon.co.uk/Newsun-NS-M003-LED-Luggage-Compartment/dp/B00WM8ELNK/ref=sr_1_1?keywords=golf+gti+boot+led&qid=1574547620&quartzVehicle=121-1628&replacementKeywords=gti+boot+led&sr=8-1
I can't fathom VAG logic.  My 15 plate A3 had an LED light in the boot but the car interior had traditional bulbs.  The 19 plate GTI has LED lights in the interior, but a traditional bulb in the boot.  Cost savings, presumably.
Golf GTi Performance Edition (2019), 5dr, DSG in Isaac Blue, Dynaudio & Brescia alloys.
Offline Talk-torque
« Reply #2 on: 24 November 2019, 07:40 »
I know, from experience, that, if you fit an ordinary led equivalent festoon bulb, it doesn’t go completely off when the hatch is shut. Presumably the canbus functionality of this one means that it will. Interested to know.
Roger.
Offline golfdave
« Reply #3 on: 24 November 2019, 10:24 »
I have a Phillips LED festoon bulb..& to make certain it shuts off I soldered a resistor across the bulb...
details in my build on this forum here:-
https://www.golfmk7.com/forums/index.php?threads/vw-golf-mk7-estate-gt-spec-tungsten-silver-1-4tsi.326479/page-5#post-6767303
Offline Andy198
« Reply #4 on: 25 November 2019, 17:30 »
I've bought and installed the one linked in Mutley's post. Its an easy enough job, its the whole housing that is replaced, not just the bulb and the light is a LOT brighter - good spread of light across the whole boot.
I've just checked in the dark, unlocked the back and folded the rear seat down and I can't see the light on at all, dim or otherwise so happy days.
Good spend for £8.99 as I use the boot a fair amount at all times. Cheers Mutley for the tip.
GTI PP Mk7.5 with DCC, Sunroof, Brescias / BBS SR & 90% Tints
Offline Rob_benton
« Reply #5 on: 25 November 2019, 20:25 »
I’m going to order one too ! Thanks everyone
2014 gti pp dsg
Offline 2007GTI
« Reply #6 on: 26 November 2019, 11:36 »
If you can wait, half the price from China, for the same thing. It says Mk5, but they are all the same, I got mine from china, all good.
https://www.ebay.co.uk/itm/LED-Auto-Trunk-Luggage-Light-Error-Free-Suit-For-VW-Golf-MK5-Passat-Jetta/183913677758?hash=item2ad21c03be:g:YKwAAOSwblldS-eT
Offline Rob_benton
« Reply #7 on: 27 November 2019, 18:02 »
I got my led light unit today and recommend it. It’s definitely brighter.
2014 gti pp dsg
steve12345
« Reply #8 on: 27 November 2019, 20:13 »
I’ve ordered one today as well.
Any tips on how to fit it?
Offline Andy198
« Reply #9 on: 27 November 2019, 21:20 »
If I can do it, anyone can.
There’s a small notch on each end of the light. Use a screwdriver on the one nearest the back of the car to push the metal clip in and gently prise it out of the housing. Pull the housing out and unclip the wire connector. This is the more challenging bit as you need to pinch it and wiggle it free whilst not getting your fingers burned on the lit bulb. Once it’s out, just connect the new one and slot it back into position.
There’s videos on a YouTube for a better idea, but it’s easy enough.
