Author Topic: Fuel filler flap  (Read 5899 times)
Offline Upperoilcan
Fuel filler flap
« on: 21 November 2019, 20:54 »
So I have my  14 plate GTI and I have a problem opening the flap to put petrol into the car.
It's an intermittent issue as sometimes it will open and sometimes it won't.
Are there any known issues?
Cheers.
Mk7 GTI in black,DSG,fully loaded.
Offline Watts
Re: Fuel filler flap
« Reply #1 on: 21 November 2019, 21:17 »
Yes, google it, lots of information online. Mine was getting stuck and was sorted under warranty. It's making a bit of noise occasionally again. Get it sorted asap as it'll get stuck at a rather inconvenient moment...
Previously:
Offline Upperoilcan
« Reply #2 on: 21 November 2019, 21:33 »
Thanks for the reply, My car is under warranty from the garage I bought it from.
No recall from VW then?  :grin:
Offline Carbon VW
« Reply #3 on: 21 November 2019, 22:09 »
My 2013 had this from the factory. I went to fill the car up for the first time and felt a right fool not been able to open the flap ! Was fixed under warranty. Supposedly they shaved a little bit off the flap somewhere to stop it getting stuck.
Mk7 CSG GTi 6MF Stage 1, CSS backbox
Offline Moro
« Reply #4 on: 22 November 2019, 10:55 »
That's what they told me too.
GTi Reflex Silver 5 door DSG: Sat Nav Pro; Dynaudio; Panoramic Roof; ACC; Keyless; Winter Pack; Reversing Camera
Offline SRGTD
« Reply #5 on: 22 November 2019, 11:21 »
The issue on early mk7 Golfs was generally the fuel flap actuator pin was catching on the part of the filler flap that it slots into when the car is locked. The actuator pin then didn’t (or couldn’t) retract far enough or not at all the next time the car was unlocked, preventing the flap from being opened.
As @Carbon VW has said, VW’s solution was to shave some of the plastic off the offending part on the inside of the filler flap to stop the actuator pin getting stuck.
It’s possible that if this problem is now happening for the first time on a 14 plate GTI, then it might be the fuel flap actuator that’s faulty and showing signs of failure, in which case it would need replacing.
Gone but not forgotten;
2016 Polo GTI; Blue Silk
Offline Talk-torque
« Reply #6 on: 22 November 2019, 13:56 »
Might just need a spot of lube.
Roger.
Offline Mutley75
« Reply #7 on: 22 November 2019, 14:01 »
As the actress said to the bishop.  :laugh:
Golf GTi Performance Edition (2019), 5dr, DSG in Isaac Blue, Dynaudio & Brescia alloys.
Offline Talk-torque
« Reply #8 on: 22 November 2019, 18:29 »
Exactly!
Roger.
Offline Jim_mk7.5
« Reply #9 on: 25 November 2019, 09:16 »
Mine started playing up yesterday, which is bad/annoying timing as just had 5 visits to the dealer to sort out the rather damp headlight  :sad:
NOW - 330e M Sport
