Author Topic: Nose/Vibration in dashboard  (Read 2883 times)
Offline Guillermogamdel
« on: 19 November 2019, 16:47 »
Hello, everyone:
So I have this problem with my car. It's a Golf GTI 35 Anniversary 2012, and whenever I have the car in Parking or I'm completely stopped, this noise can be heard. I attach video so you can listen to it. I think it's coming from the dashboard from the passenger side but I'm not sure. Has anyone had the same problem? If so, what was causing the problem?
Offline Snoopy
  • Moderator
  • Geoff.
Re: Nose/Vibration in dashboard
« Reply #1 on: 22 November 2019, 09:37 »
I cannot see the video but the only thing on the passenger side is the blower motor for the heater. You may have leaves stick in the filter/fan or a worn motor. r. If you remove the cover under the dash you can access the cover were the pollen filter is. Slide the catches across and remove the filter and clean out any rubbish inside and then clean or replace the pollen filter and see if that helps.
Current Garage:
35+ years of GTI ownership.
