Author Topic: 91 gti 8v Annoying rear knocking noise  (Read 3701 times)
Blue MK2
Re:91 gti 8v Annoying rear knocking noise
« Reply #10 on: 28 October 2003, 20:26 »
So any garage should be able to change these rear axel bushes?
golfvr6
« Reply #11 on: 28 October 2003, 20:29 »
Yep should be able to.
Offline mpgscott
« Reply #12 on: 29 October 2003, 19:39 »
Thanks for the response.
Which part is the bump stop that is being talked about? is this the rubber bush at the top of the shocker assembly.
I think i need to remove the shocker to have a look.
1996 VR6 Highline
2007 Aprillia Tuono
Offline filthy
« Reply #13 on: 10 December 2003, 00:00 »
When I changed my shocks, I overtightened the nut that holds the upper spring cup on, which crushed the tiny circlip that sits in the groove on the rod.This meant that the shock wasn't moving when the spring compressed, and it was knocking like a bastard- took me ages to work out what it was!
Having trouble keeping it on the straight and narrow?  www.powersteeringstore.co.uk
golfvr6
« Reply #14 on: 10 December 2003, 14:30 »
The bump stop sits on the shock absorber rod, its easy to check with it still on the car.
