Author Topic: Back Box Exhaust Heat Shield loose/rattlin'  (Read 3072 times)
Offline Papa John
« on: 17 November 2019, 16:49 »
Evening all.
The rear box exhaust heat shield has come loose. It's not noticable when the car is running at all, just twangs when you shut the boot or give the back box a thump.
Anyone came across this before on a MK7?
I've been meaning to remove the resonator for a while, so may well do that and at the same time the shield is either fixed or removed, as I live in Scotland, not Dubai.
Thoughts?
Cheers, Papa John.  :nerd:
2015 Tornado Red 5dr GTI PP, Manual, Austin wheels.
Offline barrym381
Re: Back Box Exhaust Heat Shield loose/rattlin'
« Reply #1 on: 17 November 2019, 17:28 »
It shouldn’t take much to put it back on if it’s not rotten  :smiley:
Offline Mickche
« Reply #2 on: 17 November 2019, 19:23 »
It happened with my 65 Gti last week so l used a tie wrap to tighten it back in place.May last forever now.
Offline Papa John
« Reply #3 on: 17 November 2019, 19:24 »
Should hope not at just 5-years-old and just over 50k miles? Will need to get the bastid's rear end up in the air and have a look?
Cheers.
Offline barrym381
« Reply #4 on: 17 November 2019, 19:32 »
Cheers.
Hopefully it isn’t to bad but I’ve seen them rotten after 18mth the same as rear brake discs
